Question about Cameras
Change the hold key to touchscreen - Cameras
  • 906 Answers
Inorder for us to assist you, please advise us your camera model, brand and type.
Thank you.
Posted on Aug 01, 2010
My asus sonicmaster laptop keys p 0 and / type the wrong characters. This can be corrected by holding down the fn key. This does not happen with the touchscreen keypad.
If you go to Control Panel and check under Clock , Language and Region, then check under "Change keyboard or other input methods" and make sure it's set to you correct geographical region
Oct 18, 2014 | Computers & Internet
How do i enable touchscreen on panasonic toughbook cf 30ctqazbm
The first thing I would try on any Panasonic Toughbook with touchscreen would be to enter the BIOS upon start-up by pressing the "F2" function key. When you are in the BIOS, there is a setting on the 2nd screen tab "Main" which says "Touchscreen:". This should be set to "Enable" instead of Disable. Then you press the "F10" function key and the message: "Save configuration changes and exit now?". Press "Yes" and the toughbook will reboot and your Touchscreen will be enabled at the BIOS level.
Good Luck!
Regards from Richard, Montreal based Panasonic Canada Authorized Toughbook Dealer since 1989.
Dec 27, 2012 | Panasonic Toughbook CF-30 Notebook
Brother mfc-6490cw lcd screen shows no display (just the backlight is on)
Procedure1: Changing the LCD Contrast setting
  1. Press Menu.
  2. Press the Up or Down Arrow key to choose General Setup.
  3. Press OK. (For touchscreen models, skip this step.)
  4. Press the Up or Down Arrow key to choose LCD Settings.
  5. Press OK. (For touchscreen models, skip this step.)
  6. Choose LCD Contrast and then choose Light, Med, or Dark.
  7. Press OK. (For touchscreen models, skip this step.)
  8. Press Stop/Exit.
Procedure 2: Changing the Backlight Brightness setting
(This option may not appear depending on the model of your Brother machine.)
  1. Press Menu.
  6. Choose Backlight.
  7. Do one of the following (The menu varies on your model.):
    • Choose Light, Med, or Dark.
    • Press the Left Arrow key to make the backlight darker or press the Right Arrow key to make the backlight lighter.
  8. Press OK. (For touch screen models, skip this step.)
  9. Press Stop/Exit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 28, 2011 | Brother MFC 6490CW InkJet Printer
My phone isnt picking up the sense to touchscreen, everyone in my family has tried to unlock my phone but the touchscreen doesnt pick up a sense, and its just frozen it will power off and turn back on...
A friend of mine had this same problem with an LG Ally. Eventually he had to remove the battery from the phone and replace it before the screen would respond. Some other things to try if that doesn't work:
  • Remove any screen protector you may have put on the phone. It is rare, but sometimes these can interfere with touchscreens of certain types
  • Reset the phone to the factory defaults (steps below):
  1. Turn the power off.
  2. Press and hold: Home Key + Power Key + Up or Down Volume Key.
  3. Turn the power on, while keeping the three keys pressed.
  4. When the LG logo is shown, release the keys.
  • Failing the above, I would return the phone to the retailer from which it was purchased. It's possible that the touchscreen is simply flawed.
Mar 07, 2011 | LG Ally Cell Phone
Nuvi 760 powers on but the touchscreen will not work
If the Touch Screen is not working properly, Calibrate the touch screen..
Turn he unit off then on.... Slide Power Key to the right ( lock )
Hold finger on screen for about 30 seconds until calibration screen appears... for on screen instructions
May 10, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Iphone touchscreen control not workinng.i can get to turn on in manually but in touchscreen only turn off working
Try resetting the phone. With the iPhone turned on, press and hold the square key and the power key until the phone turns off, then turns on. Release the keys when you see the apple appear on the screen.
Jun 26, 2009 | Apple iPhone Smartphone
Can I unlock my T.mobile with my keyboard?
1) Open the keyboard.
2) Press the dash looking key above the 'R' and 'T' keys to enter the Unlock mode. The screen will change asking to tap "Unlock" or press "*".
3) Hold the ALT key and press the 'V' key (really '*').
This will unlock the unlock the unit.
Jan 12, 2009 | T-Mobile Wing™ Smartphone
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
Touchscreen
try calibrating the unit
Oct 17, 2007 | Pioneer AVIC-N1 Car DVD Player
Bose p1 touchscreen remote
press and hold the mute key for about 5 seconds until you hear a beep, then wait about ten seconds
May 25, 2007 | Bose 023795 LCD Touchscreen Remote Control
Cameras Logo
12 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
