Question about GoVideo VR3845 DVD Recorder/VCR
I copyed a vhs to dvd but it will not highlight the finaliz option
  • 3,230 Answers
Well you can remember to finalize the recording DVD cannot be playback on standard DVD players. You can add chapter stops to the finalize  DVD by finding the right spots and pressing the relevant button on your remote. When you have finished managing the content of the DVD, finalize it.
You can make sure the following steps are correct -
1. Connect DVD recorder to VHS player.
2. Insert a DVD disc to DVD recorder.
(Check the compatibility of your DVD player with the DVD disc and select the one which supportable)
3. Position the VHS tape to the beginning and check the input signal of DVD recorder.
4. Start recording (Start recording and then start playing the VHS tape. Moniter the recording process.)
5. Finalize the recording (you need to press chapter stop by using the remote control to finalized the disk).
Good Luck!!
Thanks
Posted on Aug 01, 2010
I have a grundig gr1000(b) vhs/DVD combo. Is it possible to record from video cassette onto DVD? It doesn't seem to be mentioned in the instruction manual. Thanks for your help.
Yes! You can select to copy from VHS to DVD or DVD to VHS, set the VHS tape ready to play and press pause, then put a blank recordable DVD disk in and then select copy, the options for VHS to DVD or DVD to VHS can be selected and then it will copy, when the tape gets to the end it will turn off itself, if you want to stop earlier you will have to stop it! Hope this helps.
Nov 02, 2014 | Televison & Video
A BTPASS CODE FOR COPY PROTECTION FOR A LG RH2T160 DVD RECORDER
Try this one:
Press Home on remote.
Go to setup
Scroll down list to highlight lock icon
Press 0 seven times
You will get a message saying "Congratulations Region Change Free [Yes]"
Press enter on remote.
Hope that helps........
Aug 26, 2008 | Televison & Video
Daewoo DVD-T "copy not possible - this media cannot be copied" when trying to copy from VHS (tape is not copy protected) to blank DVD-R and +R media. Same problem with all DVDs and VHS tapes
You can only copy non-commercial VHS tapes that you have recorded yourself to DVD. You can\'t make copies of most commercially made VHS movies due to copy-protection.
Dec 29, 2013 | Daewoo DV-6T955B DVD Player/VCR
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
On the Panasonic DMR-E75V DVD Player / VCR Combo; I lost my manual; how do you dub (copy) the vhs to dvd?
You can enter the menu option on-screen - [FUNCTIONS] button, then, look for 'COPY' then select VHS as source DVD as destination.
Or you can download a .pdf copy of the manual ONLINE - it's free for this model.
http://service.us.panasonic.com/OPERMANPDF/DMRE75V.PDF - you can save this manual for future use.
Feb 23, 2011 | Panasonic DMR-E75V DVD Player/VCR
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Dub vhs to dvd
Make sure that your system is on VHS before you press the dub button. you should then get a box that asks you do you want to record from VHS to DVD and it asks you to confirm this. you press the left arrow button so that the yes box is highlighted and then press enter and your dubbing should begin.
Aug 28, 2009 | Broksonic DRVCR900 DVD Recorder/VCR
Funai HDR-B2735D HDD/DVD/VCR how can i copy vhs to the hard drive
If you press the dubbing menu button on the remote it brings up your options so you can copy vhs to the hard drive , it will show you a list on your tv ,vhs-dvd. vhs-hdd which is what you want.Then click speed you want and start dubbing.
Dec 18, 2008 | Funai PY90DG DVD Recorder
Menu question
if the tapes are store bought movies (on vhs) you will need to buy a copy guard eliminater...you dvd recorder was made not to record copy protected materal
Dec 07, 2008 | Samsung DVD-VR357
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
GoVideo VR3845 DVD Recorder/VCR Logo
198 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
