Question about RCA HD61LPW175 61" Rear Projection HDTV
RCA 61 DLP
DO YOU KNOW WHERE I CAN GET A CHEAP BALLAST,CHEAPEST I HAVE FOUND IS 312.00.ILL SETTLE FOR A GOOD USED ONE.GOING TO IRAQ NEXT FRI,NEED TO GET IT FIXED BEFORE I GO.
  • RICHARD8X5 Apr 27, 2008
    NEED A BALLAST FOR HD61LPW175YX1
  • RCA Master
  • 8,617 Answers
See my last post to you the 5 blinks means defective lamp I included a link where you can get a replacement
Posted on Apr 25, 2008
  • Sonny Berry
    Sonny Berry Apr 27, 2008
    Thats a fairly exspensive part Richard. The site I work for as a repair tech sells them new for 269.95 . I am not sure if you can find a used one that would be good. Let me know if I can assist you further.
How do i find the ballast in rca dlp tv
I just had an issue with my rca hd61lpw42, I had replaced the lamp and got the same five blinks you described. I took out the ballast the smaller circuit board, its in front of the light and mounted to the front of the tv. To get to it you remove the back cover with the tv cooled down and unplugged of coarse. Be extremely careful when removing the ballast as it normally operates at about 336 volts dc. its basically no amps but it will still throw you across the living room. The being said I found another site that discussed our issue on the ballast going bad. It is not the whole board that is bad normally. There is a solder joint in the middle of the circuit board coming up off the bigger board and that solder joint normally goes bad and causes the issue. All I had to do was remove the board and resolder the connection and reinstall. But you can get them on ebay for $50. iif you have the money or no soldering experiance I would suggest that route. The site is http://www.ebay.com/sch/i.html?_trksid=p4712.m570.l1313&_nkw=%09+RCA+Ballast+Assembly+%28261629%29&_sacat=0
Now I hope I can keep the light tunnel together :-)
Aug 10, 2012 | RCA HD61LPW42 61" Rear Projection HDTV
I'd like to know where I can get a replacement wire to connect the lamp ballast to the J4 input in my rca HD61LPW42 rear projection TV. I've gotten no response to an email I sent RCA a week ago. These...
hey mcd5brady, what was the solution to your last problem w the tv? ( replaced bulb and ballast but still no picture) my tv has same problem and dont know what to do next. any info on a solution would be greatly appreciated! post back or email. dellbino@aol.com
thanks
Jan 09, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Rca model m61wh74syx1 is turning on with no pitcure and blinking 5 times then trying to restart
Hi,If your tv is around 1-2 yrs and haven't replaced the lamp it might be time to replace it.But if you hear clicking or continually trying to restart it could be your ballast ,which is the board that powers the lamp.The lamp you will need is the 270414 Found the lam pyou need here: http://www.discount-merchant.com/RCA-HD50LPW164-Original-OEM-Lamp-P-N-265866-p/rca-hd50lpw164-265866.htm?Click=48173 Good luck and God bless you!
Jan 05, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD50LPW42 Shuts Down after 30 mins
Well it seems you may have an issue with your ballast that it's losing the energy it used to have , but we would need more info for a more accurate answer about this, discountdashmerchantdotcom
Jul 24, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 - no picture
I haven't worked on an RCA DLP but have on Samsung DLP, based on your description it sounds like the color wheel is bad. Take the back off and turn on TV make sure its not a fan making the noise ,but most likely its the "wheel" it is inside the light engine probably right next to where the lamp is plugged in. If the whine comes from this area definitely the wheel.
Apr 26, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung DLP TV won't turn on
This sounds to me like one of two possibilities. First, check your ballast. If you're going through bulbs faster than you think you ought to be, you may have a ballast that is overloading. Its the 3" x 8" circuit board that connects directly to the bulb. They are plentiful and often cheap. Thats what I'd try first. If that doesnt' do it, I would invest in a new power supply board. That the board that the tv power cable hooks directly in to. This should give you a start, Comment back if you still need further help. Good luck.
Feb 05, 2009 | Samsung HLN617W 61" Rear Projection HDTV
RCA DLP TV needs color wheel replaced
I used the internet and found others who had the same problem. Two individuals had a brief description on how to replace the color wheel in a DLP TV. Three small torque screws and a ribbon connector was all that was need for removal; once the access panel on the back was opened. I would guess that this process is the same for all DLP TV's, with some small variations!
Nov 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No sound, just clicking noise
Is your TV a SAMSUNG DLP TV Model HLN437W Rear Projection Digital HD?
If so I found a TROUBLESHOOTING GUIDE @
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=02010300&model_name=HLN437W
A probably INTERACTIVE ONLINE SERVICE REQUEST FORM @
http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
PHONE #S FOR SAMSUNG:
mobile phones: 1-888-987-HELP(4357)
  • Mon - Fri : 7am - 9pm (CST)
  • Sat : 9am - 6pm (CST)
digital HDTVs: 1-800-SAMSUNG (1-800-726-7864)
  • Mon - Sun : 9am - Midnight (EST)
printers: 1-800-SAMSUNG(726-7864)
  • Mon - Sun : 24hrs
IT Products for Business: 1-866-SAM4BIZ(726-4249)
  • Mon - Fri : 9am - 9pm (EST)
All other products: 1-800-samsung (1-800-726-7864)
  • Mon - Sun : 9am - 9pm (EST)
To see PHOTOS of REPLACING a SAMSUNG DLP TV ballast go to:
http://forum.doityourself.com/electrical-c-d-c/248376-testing-ballast.html
Hope this is helpful.
Good Luck!
Jack iaria
Nov 25, 2008 | Samsung HLN437W 43" Rear Projection HDTV
61 ballast
You can get the ballast RCa part number 269043 at this link for 269.95. You have to leave an email stating what you want as they dont list all parts that they have at the warehouse, But I know they carry that ballast and they give free installation instructions with any part they sell. They will respond quickly with the info you need.
http://servicemanuals.vstore.ca/
Apr 27, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
61 RCA
Your model is an ATC336 Chassis DLP when the LED blinks rapidly 5 times every 20 seconds that is an error code for a defective lamp. Your lamp number is RCA part 269343 you can get one here with fast shipping on sale for 169.00
http://www.purelandsupply.com/GeneralSearch.aspx?search=269343
Let me know If I can assist you further.
Apr 24, 2008 | Televison & Video
RCA HD61LPW175 61" Rear Projection HDTV Logo
117 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
