Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Why have i only got half a screen - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
  • Texas Instru... Master
  • 7,993 Answers
The calculator can be split in two. This is done by selecting certain MODE options as shown on the line that starts with FULL
In the Full option the screen is complete (regular screen configuration)
If you highlight HORIZ and press ENTER the screen will be split HORIZontally as
The upper part is for any graph and the lower part for the main calculator screen
Similarly, if you highlight G-T and press Enter, the left part of the screen displays the Graph screen anwhy have i only got half a screen - 7784ef5.jpg part the Table screen.
These are the normal instance where the screen of a Ti8*Plus is split in two.
Do you recognize any of these?. If you do just select Option Full in MODE screen to restore the full screen. If you do not, then I have no idea why you only have half a screen.
Posted on Aug 01, 2010
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Can you help me , my Apple iPad screen only shows half the screen . Can you help me ?
Loose connection internally or moisture...try putting it in a bag of rice
Jul 04, 2014 | Apple Ipad I-pad
Lcd tv half screen dark
my friend,your prossesor is not working the way it should be,thats why your half of the screen is dark and sometimes goes off, bring it repair shops and there'll get it fixed.
cheers
Dec 24, 2013 | Televison & Video
I have a Vizio SV47oxvt1a flat screen LCD TV with a video problem. Half the screen (right) half displays different colors then the (left) half. Picture is clear both sides, just divided in half.
Most likely the screen driver has failed, thay atached to the screen and not replable! ps I don't fix flat screens under 46'' any more because of price.
Aug 06, 2013 | Vizio Televison & Video
Lg37lf65-zc turns on but half the screen is normal other half is like a white haze but can still see all image
Hello... The T CON board might be the problem. All T CONs use one half of the circuit to drive one half of the screen, and the other half to drive the other half of the screen. I have seen TVs with the whole screen "white-washed", and the T CON was bad. Of course, there is a possibility that the LCD panel is bad. T CONs are usually inexpensive, so it's worth trying. I hope this helps!
Nov 26, 2017 | Televison & Video
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Half of the screen only is functioning
ok you have defective vertical amplifier and convergence correction circuit!
Oct 21, 2007 | LG 42PC1DA 42 in. Plasma HDTV
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
344 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
