Question about Canon EF 100mm f/2.8 Lens
The lens isnot completely enter to it's place and their cover is always opened
3 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: My lens cover can't open and close completely.
Try this as a last resort. This blog post outlines repair procedures for a stuck lens covers. An A400 is used as an example. But for the A620, you might want to extend your zoom all the way out before removing the camera's batteries. Also you'll be applying the ring loosening rubbing alcohol along the barrel's perimeter instead of the front as shown in the procedures.:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Good luck, and remember do this only as a very last resort. Oh, and please post how it went should you decide to try the repair.
Posted on Nov 24, 2007
t00nz
  • 4738 Answers
SOURCE: The lens cover doesn't open fully Canon A630
Sure it is, and repair isn't that hard. See this link for tips on repair of sticky automatic lens covers. Recommend reading the reader's comments section of the link for additional tips. Especially pay attention to the vacuum cleaner tip.
Posted on Feb 08, 2010
Tz10 lens cover sticking
My TZ10 problem was the opposite, the cover wouldn't open. I just resorted to surgery with needle-nose pliers and a carefully wielded Stanley knife, and removed the cover completely without opening up the camera or the lens assembly. No big deal not having a lens cover, the thing lives in a leather case and it doesn't take a moment to wipe the lens with a tissue if it gets dusty. The camera is 4 years old anyway. Solved by 'amputation'.
Jul 29, 2012 | Panasonic Lumix Cameras
The lamp cover light is blinking then projectoe gose off
hi,
There is two possibilty for this problem one is the lamp cover is not properly placed and the second one is the lamp has reached end of its usful life span.
First of all check the lap cover is propely placed or not. if its ok then try to reset the lamp hour.
For that press the menu button and select setup and then select Lamp setting and reset the lamp. It is reccomented that the lamp reset should only be don after replacing the lamp.
OK
Oct 06, 2011 | Sony Bravia® VPL-AW10 Projector
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Kodak DX7440 Lens Cover does not open or close properly
It is a common, but in most cases intermittent problem with many cameras regardless of brand/model. I also own Kodak DX7440 since late 2004, and I had this problem twice, in 2007 and 2008. First suggestion: fully recharge the battery, it helped me the first time. Second: play with the lens cover, that is try to open/close it with the camera on/off. With me, in 5 min of these attempts, it suddenly fixed itself and stays this way for one month now. Another suggestion: dont use a toothpick, since it can scratch the lens. Use a q-tip, and to avoid cotton threads sticking to lens, wet the q-tip and let it dry.
Jan 03, 2008 | Kodak EasyShare DX7440 Digital Camera
I cant take photos
ok.under the lens cover there is a small switch which may lose it's place.
to find it remove the batterry cover , remove the two screws on the body of lens cover,then remove the rear cover (plastic and metal-one body) and you''ll find the tiny switch.Put it in a right place to work when lens cover open.
Nov 13, 2007 | Sony Ericsson K750i Cellular Phone
Camera lens cover
Broken or damage a small switch under lense cover create this type problem
Apr 30, 2007 | Sony Ericsson K750
No startup on lens cover opening
well the problem it´s on the switch that turns on the camera that is located under the lens cover.... this swith is glued to the front cover and lots of times gets unglued, u need to remove the lens cover by removing 2 screws on the bottom part of the lens cover, after that just pull the switch slowly and glue it. don´t use 3 seconds glue use a more viscose one. good luck
Feb 14, 2007 | Olympus Stylus 400 Digital Camera
Lens not opening when turning on....
there is a friction in the cover movement, due to some sand or foregion partical. blowing a heavy puff of air, by blower may solve the problem.
Oct 29, 2006 | Sony Cyber-Shot DSC-P200 Digital Camera
Open cover
The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
Aug 31, 2005 | Olympus Camedia D-510 Zoom Digital Camera
Cover open
Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
Canon EF 100mm f/2.8 Lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
