Question about Equator EZ 3612 CEE Front Load Washer/Dryer
After reseating the drum's belt, everything appeared to be working properly in the wash. Success! When I got up this morning, though, the (small) load of clothes were hot but wet. Not sopping wet, but not dewy. Help please?
  • Equator Master
  • 12,061 Answers
I wonder if the belt is not slipping, maybe it should have been replaced, if it slips then it will NOT dry the clothes out of the water. Also perhaps the motor, or control circuitry, has been damaged? and again, it is not spinning fast enough to dry out the clothes, or it is not cycling long enough. OR the heater isn't heating properly in any event i have included a link for your service and repair manual. This has troubleshooting steps to assist you to isolate your problem and hopefully repair.
http://laundry.manualsonline.com/manuals/mfg/equator/ez_3612_cee.html
Posted on Aug 01, 2010
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Cp5225dn error 59.0240
This error is indicative of a motor not working properly.
Reseat all cartridges and drums and remove and reseat the belt.
I've seen the belt cause all kinds of issues.
Feb 07, 2014 | HEWLETT-PACKARD Color LaserJet CP5225...
There is a belt sitting in the washer at the base of the tub and what appears to be a small white plastic piece between the alternator and motor is this where the belt belongs
i no expert on that model but i seen a few inside of a washer there a moter small siver thing the belt goes on there and around the drum i say the plastic thing is part of the cog for the moter but cant be sure without seeing it does the drum spin or move when turn it on if not then that defo the drum belt
Apr 04, 2012 | Whirlpool LTE5243D Top Load Stacked...
Belt replacement- broken belt on a lde7600acw, older dryer. belt has been replaced but won't line up properly on idle pulley and motor? It appears maybe the tensioner is not set up rigt, maybe the belt...
Remember, the belt DOES NOT sit in the groove of the drum but about an inch from it in the direction of the front.
Also, the belt sits on the drum with the grooves facing away from the drum, not on the drum, a common mistake. If you have a new Genuine Maytag belt then there is a diagram of how the belt fits onto the tension pulley.
Jul 23, 2017 | Maytag Dryers
Falal error 173 on oki c5650 after changing fuser unit
Cause:
Resolution:
http://my.okidata.com/PP-C7200.nsf?opendatabase
Apr 23, 2010 | OKI C5650n LED Laser Printer
Dell 3010cn printer, says reseat drum contact support. I took drum out and put it back in but don't see anything wrong. It feels secure and I restarted the printer, but no luck.
Hello sir; Pull out the drum cartridge, look around the cartridge you will find a small memory chip, remove it, shoul d take care this problem.
Nov 28, 2009 | Dell 3010cn Laser Printer
Drive belt on Maytag Neptune washer not centering on large pulley on rear of drum. The belt rubs against the veins of the drum ever so slightly and is rubbing a small grove in the rear of the drum. The...
Do you know the story of Kakima and Lil J? Many years ago, a great battle occurred. Kakima struketh with great force and angst, but i passed him, and prevailed. With the greatest achievement on the website, i ran. but kakima chased me, and called the admins! How dare he? What has he doneth to the lil J? He got me banned, and i retrieved balance. I never came back until today. Im finally back to the city of england.
Jun 28, 2017 | Maytag Neptune MAH5500B Front Load Washer
WASHING MACHINE DRUM WILL NOT TURN
There is no adjustment provided for lining up the pulleys.
If it comes off then there are a couple of reasons that come to mind,the belt is too slack, the belt is worn,the drum is out of alignment with the motor pulley, caused by worn drum bearings, the motor is loose, a loose drum pulley, or you are not lining the belt up properly, overloading can also throw the belt off.
Hope this helps.
Plz leave feedback.
Ta.
Dec 09, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine will not spin dry but washes properly
CLUTCH MAY NEED TO BE REPL/ IF DOES NOT SOLVE REP/ TRANSMISSION
Nov 28, 2008 | Maytag SAV365ZAWW 3.3 cu.ft.
Drum/motor belt
you dont need to untension it, firstly place the belt on the small pulley on the motor then feed onto the main drum pulley gently turning it as you go, it may feel as though it wont go but it will as long as you have the right belt that is.
hope this helps
Jul 02, 2008 | Zanussi FC1200W Front Load Washer
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
