Question about Water Heaters
I AM LOOKING FOR A DIAPHRAM FOR AN OLD JUNKERS GAS GEYSER. I CAN SEND A PHOTO VIA E-MAIL. I AM LIVING IN KEETMANSHOOP,NAMIBIA AND MY CELL IS OO264812464189 OR E-MAIL IS ajblaauw@keetmansmunicipality.org.na Please any-one whO can help or refer me. aNDRE bLAAUW
2 Suggested Answers
mrhotandcold
  • 248 Answers
SOURCE: junker gas geyser, looking for spares in Cape town
onlines yuor best hope
Posted on Oct 12, 2009
My kwikot geyser trips when I turn it on its 7 year old
If breaker trips check
- elements being to high in ohms resistance (worn out)
- shorted elements
- short to ground
- improper wiring or voltage per nameplate
May 19, 2017 | Water Heaters
Which is the best Repair center for geyser?
Dial fix is the best service center for geyser.Also called Water Heater, Geyser is a household appliance consisting of a gas or electric heating unit under a tank in which water is heated and stored.
Geyser Repairs Services in Hyderabad Dialfix
Feb 03, 2016 | Water Heaters
Looking for manual for Junkers gas geyser 250 KV3 P3152500TAI
they all work the same
http://www.americanwaterheater.com/support/manuals/res-gas.pdf
Nov 08, 2014 | Water Heaters
Junkers wr11 has no spark and no power
Is it gas or electric? if it is gas and has a pilot, and the pilot is out. If you don't smell gas go through the start pilot proceedure. when the pilot is running it produces a small electric current sufficient to hold the main gas valve open; then the temperture sensor allows the unit to keep the water heated.
Oct 29, 2014 | Water Heaters
Vaillant gas water heater - pilot light only, not lighting the main gas ring when tap is turned on..
first check to see if the thermocouple is close enough to the pilot. if it is and won't light the ring, replace the thermocouple.
Mar 01, 2014 | Water Heaters
Had burst pipe, used geyser water to bath kid. Water supply now restored but geyser switch in box keeps on tripping... Help!
Use hair dryer and see if you can dry out parts.
Often, when electronics get wet, they cannot be repaired... like dropping cell phone in bucket of water.
Gene
h
Aug 28, 2013 | Mountain Plumbing Water Heaters
Junkers water geyser pilot is on but main burner will not start
http://documents.junkers.com/download/pdf/file/7181465057.pdf Sometimes there are several parts on this model to find buit beware on some marketing technical made differences inbetween one year of build there can be some modifications inside.
Succes
May 31, 2017 | Water Heaters
Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Mar 02, 2010 | Water Heaters
Water Heaters Logo
66 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
