Want a owners manual for Drayton Tempus Three Water heater
    Novelist:
  • 120 Answers
The Tempus three actually the controller not the heater itself. It varies from when the unit was made but I see the web littered with people trying to get this info. I trawled the net for a while to try and get a link for you but my best suggestion it to either email Drayton or you can find vartious instructions for the tempus 7, 2 and 1 that might help you figure out how to use yours. I'll keep looking and see if I can get a pdf. put on.
Posted on Aug 03, 2010
Central Heating controller problem.
Y resetting,remove power supply for a short while and restart.
Dec 27, 2017 | Heating & Cooling
How to programme rc2 british gas thermostat
The British Gas RC2 is a re-badged Drayton Digistat and I managed to find installation and operating manuals for that at www.gasapplianceguide.co.uk
Go to the section 'Lost your instructions' and look for Drayton 2F & 3F Digistats (earlier type) for a downloadable copy of the manuals.
Following them got my RC2 up and running though it was a bit fiddly at times.
Hope this helps.
Oct 27, 2011 | Honeywell Programmable Thermostat Heater
Got 5 year old drayton tempus 7 when i try to put the hot water on the main electrics tripout ,heating is working fine tho'
my very first check would be the thermostat on the hot water cylinder, you may find you have a water leak on the cylinder which is dripping onto the thermostat. (quite common) another check and this is very dependant upon your skills is to check the wiring to the timer.
Sep 04, 2011 | Heating & Cooling
We have inherited a brown/beige Drayton Tempus.seven wall control unit for heating/water but do not have an instruction leaflet on how to rest it etc. Any ideas where we could get even a copy please
The instruction manual for this control unit can be found here:
http://www.heatingcontrolsonline.co.uk/instructions/Tempus7Instr.pdf
Hope this helps,
Chris
Mar 01, 2011 | Heating & Cooling
Drayton digistat 2 thernostat manual an elderly neighbour can not set it and has lost manual
Go line to Drayton site and download a manual for him and follow it to the T. It to hard setit out. Ken'Repair
Jan 22, 2011 | Heating & Cooling
I want to download a Drayton Tempus Seven instructions manual< where is it on this site?
Not sure where that document is on this site, but we were able to come across some instruction sheets on the Drayton Controls website:: http://www.draytoncontrols.co.uk/WorkArea/DownloadAsset.aspx?id=10467
It's not a ton of information on the product, but does offer some technical help.
Hope this helps,
ComfortGurus.com
www.comfortgurus.com
866-519-2461
Oct 19, 2010 | Heating & Cooling
Drayton tempus seven
I have jjust found a manual for this system. The unit has a plastic cover on, which is not that obvious first. After opening the cover there are some buttons ( i.e. Clock). First press clock and re-set correct time. Then just press the relevant button ( i.e 1st on to set the time for having the heating on first thing etc. For each day, afert pressing Day button, the same can be set.
I think the key is to realise that there is a front cover, which hides the buttons. Hope this helped.
Oct 12, 2009 | Dayton Water Heaters
Need a manual for drayton tempus 3 heating control
I've ended up with a Drayton Tempus 3 when I bought my house, and I think this is how it works. It allows you to set 2 Timers (I'll call them timer 1 and timer 2) so that you can control Hot Water or Heating On/Off times twice a day. The unit has 6 buttons - 2 for Adjustment, 2 for Hot Water and 2 for Heating. The 2 Adjustment buttons allow you adjust the Clock Time, or allow you to adjust Timer 1 and/or Timer 2. NOTE: Timer 1 is the time refered to on the Heating / Hot Water Select buttons if you press "Once". If you select "Twice" on these the both Timer 1 and Timer 2 are taken into account. For example if you want Hot Water to come on Once between 8pm -10pm, but you want Heating to come on Twice between 6am - 7am, and 8pm -10pm, you have to do the following: Set Timer 1 to 8pm - 10pm, and set Timer 2 to 6am -7pm. Then select Once for Hot Water, and select Twice for Heating. Hope this helps.
Mar 23, 2009 | Water Heaters
Wiring a Drayton Room Stat into central heating system
9 TIMES OUT OF 10 THE COLORS ARE THE SAME. MATCH THEM UP. FIRST LABEL THE WIRES ON THE ORIGINAL STAT, AND PUT THEM IN THE CORRESPONDING PLACE ON NEW ONE.
Oct 26, 2008 | Water Heaters
Heating & Cooling Logo
566 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
