Remote I changed batteries in my remote and now it looks like I will have to re-program it and I don't have the code. Can you help me ?? Mike
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Hi,well um my dish remote controller is like disactivated or something because it wont change channels,I don't know if its the remote controller or the batterys or the dish box thingy,please help.
Hi my nameis Mike Houston of DISH Network and I see there is an issue with the remotecontrol not changing channels. The first thing you will need to do is changethe batteries and I will send a link that helps with the steps for readdressingthe remote, if you have any questions or concerns please e-mail me at michael.houston@dishnetwork.com.http://www.dishnetwork.com/SupportSection/remote-control
Aug 01, 2011 | DISH Network 322 DTV Receiver
My remote stopped working can it be reset
Hello;
I found the following reference to resetting anything related to the ZN110 remote:
"This remote control works well for all the basic functions on the television: changing channels, adjusting volume, and turning the set on and off. There is not a way to program the TV with the remote control, so if you need to reset the channels after a power outage, for example, you have to do it manually on the TV set itself."
Or it could just be batteries?
Feb 26, 2011 | Zenith ZN110 Remote Control
CT-90157 Remote Control: change batteries does not turn on tv...
It is possible that you will need to re-program your remote control, it sounds as though the remote has lost it's settings. This can happen when changing batteries, usually a remote will retain the code for around ten minutes or so once the batteries have gone flat or have been removed, after that time it loses it's code. I assume the batteries are new so try re-programing the remote control for your tv with the correct code and hopefully this will work.
Hope this helps,
James
Apr 28, 2010 | Televison & Video
I want to program my dish network remote to my prima tv
Hi my nameis Mike Houston of DISH Network. I see you are looking for the remote code toyour Prima TV, we do not have the three digit code at this time but we have away to program the remote to the TV through a Power Scan. I will send you thelink that will help with these steps, http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Jan 03, 2010 | Prima C2012 TV
Remote control not working (no functions),
Do the contacts look ok?
you can check if it is working by looking at it with a digital camera
press a button on the remote
if it shows as flashing on the digital camera screen, then you know it is transmitting.
then your problem would be either the device you are trying to operate is not receiving, or the remote is using the wrong code.
if the code is wrong then look it up online. there are some helpful sites that tell you the codes and how to program the remote.
good luck!
Jan 02, 2010 | Samsung BN59-00678A Remote Control
Need remote programming codes for RCA Digital Converter DTA800B1
Use the SKU number of the RCA remote to look for the code here. Click on "Find your Remote Codes Here" at the left side of the screen.
Dec 22, 2009 | Televison & Video
Kenwood remote 0809 wont adjust volume or change inputs
I looked thru the manual and the only two or three things I would ask would be: Is it in the right control mode? Amp/TV/DVD etc. silly I know but have to ask. Ithere a light or display that lights up when you push a button? if so, is it staying on? if so you could have a button thats jammed, it happens. Lastly it could be a microprocessor error in the remote and the remote needs to be reset. I didn't get to the process of how to do it but it is in the manual. That would be the last thing to try since programming alot of devices can be very time consuming! Lastly, the strange icon you see; is it on the lcd display of the remote or on the receiver? Hope this helps, if not send a reply and I'll dig some more for you
May 25, 2009 | Kenwood VR-409 Receiver
Can't Reset TV Don"t have orginial Remote control for TV
The remote must be programmed with the correct code. With the model you have, if something goes wrong or the code is lost it uses the last programmed code.
Go to:
http://66.77.167.109/rcaaccessories/RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_IDSTR_CATEGORY_UNIVERSAL_REMOTES&ACTION_PRODUCT_ID=RCR311S
and click the link for the manual.
If your code is not listed in the book (hard to say without knowing what brand TV you have) then you can use the remote code finder on the bottom left of the nav on the same page.
Feb 04, 2009 | RCA RCR311B Remote Control
Philips universal remote codes for symphonics tv
try to ask a copy from the store where you bought the unit. or search in the internet. send me the model and ill help you search in the internet.
Dec 10, 2008 | Universal Remote Control Remote Control
Jizzz i´m desperate!!!!
jenson 300 series Sony tv codes 497,491,475,459,406 or the code you have
hold the program or setup button untill it blinks. select the tv function and enter the code you have or one i listed above then enter
Or if your remote is this 300c series your code would be 0000
you would press down and release the device"mode key"tv,vcr,ect
the red light will blink once.press and hold down the setup key untill red light blinks twice then release.enter the code the led light will blink once on each digit execpt the last one will blink twice to confirm valid code ****mode 1 is for the tv on this remote.
hope this helps
Mar 18, 2008 | Jensen JER-323 Remote Control
Televison & Video Logo
Top Televison & Video Experts
