My huawei 5830 only works when is connected into the laptop, but when i try on wireless it says i dont have an ip add and i cant get one
  • 748 Answers
Have you configured the Wireless settings and also DHCP settings of your device?
Also, the TCP/IP network settings for the wireless connection on your laptop should be to obtain IP address automatically (which is default).
I'd suggest going to the following webpage where configuration is described step by step. Ignore the mobile network settings, as they are specific to the mobile network used, and are correct in your case, since you can work using wired connection. Concentrate on the DHCP and Wireless Basic & Security settings. The choices shown are for WPA2 encryption and are the best to use. For a pre-shared key (passphrase) use something hard to guess. I would also suggest changing the SSID (name of your wireless network) to something less obvious.
Once you've done the configuration and saved it, disconnect the device and try to find on your laptop the wireless network with the name (SSID) you configured, and connect to it.
Here's the link: http://www.philmug.ph/forum/showthread.php?t=58196
Please come back to rate the answer if helped :)
Posted on Aug 01, 2010
My huawei ascend y 200 won't go online
Hi, if you are using sim card to go online change the sim card and get the saving setting for your smart phone from your sim card company,if you have connecting problem with your wireless make sure that you can connect to any wireless network if you can so your wireless modul is working fine if not you have hardware issues,if you can access the network but not go to the internet from any wireless access point so you may have problem with access point preshared key or DHCP not enabled in you access point or you have restricted because mac address or ip address or network infrastructure has problem with your cellphone so contact your network administrator or network experts,
if you cant connect to any access point so you have hardware problem go to a certified repair shop to fix it(may be your antenna is not attached to your wireless IC correctly or have some harder issues)
kind regard
Apr 17, 2013 | Huawei Ascend Y200 U8655 3mp 3.5" Ips 5s...
Hi i cant connect using wireless on my lenovo.
Welcome to fix ya
If you are having problems connecting wirelessly using your lenovo G550 here are steps that you could try
1. Press FN+F5 ( this turns the wireless adapter on/off)
2. Make sure that the wireless switch is toggled on. The wireless switch is located on the front of the laptop.
3. Make sure that the drivers for your wireless adapter is properly installed. To do this click on start then type device manager. click on device manager. click on the arrow next to network adapters. Make sure that the wireless adapter does not have a yellow exclamation point next to it. Also if you dont see your wireless adapter here check for a yellow question marrk in other device. If you dont have the driver you can download it here. www.consumersupport.lenovo.com
Apr 25, 2011 | Lenovo G550-29583AU Notebook
Wireless connection problems
fist check the setp by setp
1.check your wireless driver is install .....driver is install proparly then .
2.right click the wireless connetion propraties
3.select the tcp/ip propraties and add your
  • ip adderss
  • subnetmask ip
  • DNS ip add
and save it ....................
next setp
you are working with workgroup to add your workgroup in yor my computer proparties .............send me a repaly we have solve your problem in .........short time
Apr 01, 2009 | Toshiba Satellite A215-S7422 Notebook
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I cant connect my wireless laptop tp my comp.
Let me know the settings of your Router if needed IP address?
Yes - add your IP address into Network Connection.
No - obtained the setting in your Network Connection.
How to Add or Obtained the setting s of your IP address:
- goto Control Panel
- Double Click Network Connection
- Rigth Click then Properties the Local Area Connection
- Select Internet Protocol (TCP/IP) and select Properties
- Under General Tab they have choices to add or obtained settings.
Sep 20, 2008 | Linksys Wireless-G WRT54G Router
Tusb3410 vista
Sir , I am having Huawei Wireless Modem.(TUSB3410).For Internet connection(dail up). I am having windows xp I cant install the modem with this vista. .Please solve my problem...
Aug 21, 2008 | Computers & Internet
Wireless connection on vista!!!!!!!!!!!!!!!
Try checking if your pc is receiving a valid ip for ex. if your router start with a 192.x.x.x if your pc is really connected to your network its should also receive a ip of 192.x.x.x and if your network is unsecured and your pc is getting a 169.x.x.x ip you can try setting a static ip on your pc that's within the range of your router.
May 07, 2008 | Computers & Internet
How to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Mar 02, 2008 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
Alun Cox
David Payne
David Payne
