Question about Toshiba Satellite Pro L300 Notebook
-What have you already tried? I have tried using the passwords set, removing the battery / power supply / memory slots. The password X need to reset appears to be the boot up. When I press the on button I see the Toshiba inovation logo then it comes up with the black screen and blue prompt to enter current password XXXX if I pess ESC, ESC + f1, f2, f8, f9 or all the other alternatives it just keeps comming up with the black screen and blue prompt to enter current password. It does not recognise the password XXX after 3 attemps closes down. Read more: I need to reset or clear password on my toshiba ... - JustAnswer http://www.justanswer.com/questions/1ofof-i-need-to-reset-or-clear-password-on-my-toshiba-laptop-satellite#ixzz0vO1dDRWP
4 Suggested Answers
  • 81 Answers
SOURCE: HDD PASSWORD problem
I have had this happen to me too, and found no other way to resolve this other than just reformat the hdd and reinstall the OS. If you search further, you might be able to find a simpler fix; but if not, reinstalling your Operating System will definitely fix your issue.
Posted on Sep 05, 2008
SOURCE: Turn on my laptop, screen
Dude it's your lucky day-here's what I did given same problem and it worked. Remove bottom memory stick and locate B500. Short the two points out with screwdriver or something of the like with battery in and top memory stick in. Turn computer on while holding screwdriver in place on the two points and keep holding it there after the password prompt appears, and magically...
Posted on Dec 20, 2011
  • 22 Answers
SOURCE: satellite l655 blue screen password
This is a BIOS or HDD password. I'm assuming you cannot get into "setup"right when you fist boot the system? You will probably have to flash the bios or reformat the hard drive (or both) These are more advanced procedures, I recommend checking craigslist for a local PC technician.
Posted on Jan 04, 2012
Bios password reset
Usually if you open it and remove the battery for a few seconds...(30 or so ) ..in normal mode should remove the password cause the BIOS should reset to the factory settings ..when you cut the power..and delete all settings ..But ..there are laptops ...that will not reset ..cause they either have a separate power for the memory ..or ..the memory type used to store that info ..is not needing power to store them and remember..and in this case ..you either have to contact the manufacturer and ask for a back door master password ..and go in a disable this one ..or ..upgrade BIOS ..or reinstall it ..which is a tricky operation ...and risky ..or ..try to see if you can avoid making changes to bios ..for example ..if you want to reinstall the operation system ..and you need to rearrange the boot order ...use the F12 or F11 key instead...the one designated for the boot menu ..and just pick the cd /dvd or the usb device and hit enter ..and will work ..with no changes on bios..
If you really need to make changes on BIOS settings ..than you should try to get in side it ..and remove the battery for a few seconds..and this will reset to factory defaults ..and will probably erase the password..or ..at least you will default the settings ..and if it is a matter of recognizing new component (hardware ) this will work ..
by the way ..if the battery is not removable ..look for the pins for clr cmos..They should be visible and need to be shorted with a jumper ..and same way ..a few seconds..and this will clear the cmos (bios ) memory
Dec 09, 2011 | Toshiba Satellite A105 Notebook
Tip
Resetting BIOS password
If you have loast the password, to reset the BIOS password you need to remove temporarily the CMOS battery , so to reset BIOS settings.
Some model may be using NV Ram, in that case removing the battery is not enough.
The battery is located on the lower side on the motherboard.
On many DELL models the battery can be accessed from the side of DVD slot, battery slot, or RAM slot, without disassemblying the laptop.
On some model you may need complete disassembly (eg. Dell Le series).
The battery usually looks like a couple of coin batteries wrapped in plastic and connected to motherboard by a two wires connector.
Before disassemblying or removing covers, always unplug adapter and remove battery.
Several Dell Laptop can be set to use NV Ram to store the password.
In this case the problem cannot be solved removing primary battery, then accessing and removing CMOS battery for few minutes.
If you still cannot reset you have two way out.
Disassemble completely and access the NVRAM microswitch, or contact Dell and get master password.
You can also try one of this standard Dell factory CMOS password:
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
Dell
on Sep 11, 2009 | Dell Inspiron 8500 Notebook
Tip
Resetting the bios password for Toshiba Laptop
It working with the Satellite A135
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the black lebel back from memory module 1, I soldered PAD500 solder pads (to short circuit them), install one memory memory in slot 2 and turned notebook on, it erase the password and boot without asking for one. Then power off desolder PAD500, replace mylar. Replace memory modules. Replace battery. Power up unit, replace memory cover and screw. Whalá!! the password gone, and you can enter to bios setup to set a new password if you want.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Cant find cmos battery on toshiba satelite l300 motherboard, need to reset hdd password
You cannot reset a HDD password (if its a bitlocker one) and you have lost your encryption key reset file and forgot password.
if you mean the BIOS/Power on password then try this
Remove Laptop Battery Remove Memory Cover Spread spring clips to outside and pull out RAM memory Remove clear vinyl label opposite RAM memory slots In the upper left corner you will see JOPEN1 with a white silkscreen square Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
May 10, 2011 | Toshiba Satellite Pro L300 Notebook
Need bios password to be reset
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
or
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
don't forget to vote
hope it helps.
don
Feb 20, 2011 | Toshiba Satellite A75-S1253 Notebook
How do i reset the bios password
How to recover your forgotten laptop BIOS password? There are 3 methods, each method has its strength and weakness but I am going to talk about the 2 easy methods that works across the board for everyone. Here they are:
Method 1 – Remove BatteryFor desktop user, open up your computer casing and look for the battery. Remove the battery for approximately 5 minutes (maybe longer, depending on the motherboard) and slot it back. By removing the battery and deprive the motherboard’s flash memory of power supply, you are essentially resetting the settings back to default when the existing data in BIOS are cleared.
laptop_battery_desktop_bios_remove_reset.jpgThis method works well for desktop, however this is not practical for laptop user unless the warranty expired long time ago. This method might or not not work, it depends on the type of motherboard.
Method 2 – Reset CMOS With SoftwarePC CMOS Cleaner is the best CMOS password reset software, it works setting the BIOS to the default state or revealing the password.
reset_bios_cmos_password_motherboard_remove.jpgreset_bios_cmos_password_motherboard_remove2.jpgPC CMOS Cleaner is an easy-to-use tool to recover, delete, decode and display the superior passwords stored in BIOS whatever the brand is. Most types of BIOS are supported. It’s an bootable CD that runs on x86 and x86_64 computers. No need to pay expensive fees to experts. It’s a useful tool for users to get their lost BIOS password back, or clean passwords from an old computer bought from others.
  • Support all x86, x86_64 Personal Computers.
  • Support most BIOS, such as: AWARD, AMI, Compaq, Phoenix, Samsung, IBM, Compaq, DTK, Thinkpad, Sony, Toshiba and so on.
  • Display the superior passwords of the BIOS .
  • Remove BIOS password(will set the BIOS to default status, need reset date).
  • Set the BIOS to default state
Feb 26, 2010 | ASUS V2S-B1 (V2S-B1 + TGS-BACKPACK) PC...
Need to unlock bios password on dell laptop, have service tag # and ends in 59b
The battery looks like a couple of coin batteries wrapped in plastic.
On Dell Inspiron 8500 the battery can be accessed from a side , after removing the primary battery.
I think Dell 8500 can be set to use NV Ram to store the password.
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
Dell
Reset bios password don't remember the password to get into bios
The best solution is to remember your password. If ther is no way you can remember the try these steps..
1)Remove Laptop Battery
2)Take off Memory Cover(underneath - square cover, Sits
in middle of laptop 1 retaining screw
3)Using two thumbs spread spring clips to outside and
pull out RAM memory.
4)Remove clear vinyl label opposite RAM memory slots in
upper left corner( laptop battery slot is on right, DVD
drive is facing away from you)
5)Using a magnifying glass (unless you have perfect
vision)in the upper left corner you will see JOPEN1 with
a white silkscreen square next to it . Inside the square
post connecting the motherboard to the laptop case(this
is you ground, it is located above what looks like a
silkscreen outline of a chip)hold for 25 -30 seconds.
6) Place back your RAM memory, put in the laptop battery
the SECURITY setting tab and change your passwords. Now
hit F10 key ,yes to save and your done!
Regards,
Jeep Brainy
Aug 10, 2009 | Toshiba Satellite A135-S2276 Notebook
I need to reset the system password on a HP NC 4010 notebook
If it is a bios password, you can reset by using the jumper which should be located near the cmos battery.
Mar 16, 2009 | HP Compaq nc4010 Notebook
Acer 3089
hmm which password ??? is it the bios password or the windows password.. Any way I will give you solutions for both
THE BIOS PASSWORD
1.) unplug the computer system
2.) remove the side panel
now you have two option
OPTION 1
3.) locate the jumper jp1 or jcmos1 you can use your manual for a refrence its a 3 pin jumper located cloase to the battery
4.) the jumper is currently on 1 and 2 , set it to 2 and 3 wait a few seconds and set it back to 1 and 2
5.) THATS IT BIOS PASSWORD RESET
6.) boot system enter setup and load optamised defaults.
7. save and exit setup
OPTION 2
incase you cant find the jumper
3.)remove memory
4.)remove the battery
5.)press the power button 5 times to empty any charged capicators
6.)replace battery and memory
7.)boot ystem enter bios load optimised defaults , save and exit
TO RESET WINDOWS PASSWORD
1.) dowload hirens boot cd from here
www.phazeddl.com
you will need to search hirens when you go to the site
2.)burn off cd
3.) boot from cd
4.) use the on screen menu to fine windows password reset tools,
5.) choose the appiorate one and follow instructions to change or reset password..
THATS IT WINDOWS PASSWORD RESET..
let me know if you need any more help good luck
Jan 10, 2008 | Acer Aspire L100 PC Desktop
Toshiba Satellite Pro L300 Notebook Logo
307 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
