Question about HP Pavilion zd8000 Notebook
Beeping Noise My laptop's battery is shot, so I MUST run on AC power, plugged into an electrical outlet. The AC power cord is somewhat frayed, and sometimes shorts out. When it shorts for a split second, my laptop automatically shuts off. Because of this, the next ten or so times that I turn on my laptop, i hear a strange beeping noise in the background. It is not very loud,but it occurs about every 3 seconds. Every time it beeps, the keyboard will not type the letters that I pressed during the beep. I am a fast typer, and it affects me greatly. If I could get any help or a solution to this, I would greatly appreciate it.
  • Zandri Apr 25, 2008
    Gotcha, will do. Thanks for the help
    Genius:
  • 1,019 Answers
I Can help you out Here.
Get yourself a new Battery, and A New AC Adapter.
Before you do extensive damage to your Motherboard If You Have,nt Already.
If you know you,ve got faults, Then They Need Repairing Urgently.
Thats The Best Advise Any Expert would Offer You.
Mike @ compurepair.
Posted on Apr 25, 2008
  • Mike Waldron Apr 27, 2008
    No problem, Thankyou very much for your Rating.
    If i can ever be of further assistance, please Ask.
    Regards Mike @ Compurepair.
Tha half moon light blinks green,standby light also blinks with battery light orange light when charger is connected to my thinkpad t61p ,no booting
Step 1:
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Feb 17, 2013 | Lenovo ThinkPad T61p 15 inch widescreen...
Why is New Samsung computer battery not detected?
Step 1:
Computer Won't Recognize a Battery While desktop computers are plugged directly into an electrical outlet to obtain power, laptops rely on a battery and power cord in order to be charged. If your laptop suddenly stops recognizing this battery pack, however, it could jeopardize your ability to charge your computer and ultimately work on it at all.
Inspect the Battery With the battery unplugged, carefully examine your laptop's battery, both the battery unit itself and any cords or plugs attached to it. Make sure the battery's case is not cracked or damaged. Look for fraying cords and bent prongs on the plug. Any of these issues could cause internal damage to the battery itself, the cable or the plug, which could interrupt the flow of electricity between the battery or electrical outlet and your laptop. If your laptop is still under warranty, you may be able to get a free replacement for a damaged battery or cable. b> Check The Port b> Damage to the port on the back of your laptop the one into which you insert the power cord could cause your laptop not to recognize your battery or any cables attached to it. Turn off your laptop and turn it around so you have a clear view of this port. Using a flashlight to illuminate the port, inspect it for any dirt or debris that may have become jammed inside; gently remove any debris with a small cotton swab. A bent prong could also interrupt the circuit, making it difficult for the battery to transfer energy from the power cord to the laptop; straighten a bent prong using needle nose pliers. Avoid making invasive repairs, especially if your product is under warranty; any damage you do to the laptop in an effort to fix it could nullify the terms of your warranty. b> Wrong Kind Of Battery b> Some brands of laptops, such as Dell, will not recognize a battery that wasn't manufactured by the same company. To make sure that your battery is compatible with your laptop, consult your laptop's user guide for battery specifications (these will vary based on make and model of your laptop). b> Dead Battery b> Laptop batteries have a limited lifespan. After so many charges, they may be unable to transfer enough power from your electrical outlet to your laptop. When your battery reaches this point, a replacement may be your best option. b> Laptop Update b> Updating the "BIOS" on your laptop can help the unit better detect and recognize external hardware such as a battery. BIOS which stands for Basic Input/Output System assists in booting up your laptop, and helps run every function until you turn it off. Computer manufacturers release BIOS updates for their products routinely; these updates can be downloaded from the company's website as ".exe" files. Run and save this update on your laptop, then restart it to see if your laptop now recognizes the battery. Mac users can reset the laptop's System Management Controller (SMC). Apple reports that sometimes, otherwise unexplained errors pop up in the laptop's system, including problems with the battery's ability to charge. To reset the SMC, turn off the laptop and remove the battery. Hold down the "Power" button for five seconds and release before plugging the battery back in and turning the laptop on.
b>
Feb 07, 2013 | Samsung N210JA02 Netbook
Battery not charging
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.Remove the Battery Sometimes it's as simple as a seated battery.
hope this helps
Jan 25, 2013 | HP Computers & Internet
Battery wont charge
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. Hope this helps.
Jan 06, 2013 | Computers & Internet
Inspiron 1545-my AC adapter doesn't seem to charge my battery
Check the LED Your Dell Inspiron 1525 offers five small blue LED lights on the front left corner of the laptop that display the status of various areas of your machine. The middle light shows the charge status of the battery, with a solid light indicating charging. The light changes to a blinking sequence as it nears full charge and turns off when full. Without the adapter cord plugged in, the battery LED turns orange as the charge runs down. Check the color of the light to verify charging status.
Verify Connections and Power
Start with the simplest cause and work backwards to the laptop. Use a different electric device to check for electricity from the wall outlet. Verify that the connections of adapter cord are tight and secure at the wall outlet, the brick and the laptop. Check the adapter cord's brick for a small LED that lights to indicate the presence of electricity.
Check the Battery
Battery issues can prevent proper charging, ranging from something as simple as a mis-seated battery to as serious as a completely dead battery. If the adapter seems to be functioning properly, try removing the battery and checking the small metal contacts in the laptop. Clean any corrosion or dirt from them to ensure a solid connection. Reseat the battery so that it clicks securely into place. If in doubt, try purchasing a replacement battery and see if that works.
Check the Adapter
Unless you keep your adapter cord in one place and never move it, every day use of the cord can cause the wires inside the insulating material to fray and kink. This wears them down, and can cause short circuits. The circuitry within the brick can also short out, preventing the delivery of the proper amount of voltage to the 1525. Use a voltmeter to double check that the cord is supplying the correct number of volts to the Inspiron.
Inside Problems
Internal issues can prevent a battery from charging, such as short circuits and a broken adapter port. The adapter port, the small opening you plug the end of the adapter cord into, is attached to the motherboard to carry the electricity to the various internal electronics. If this component breaks loose from the motherboard, the electricity can't go anywhere. A repair shop can fix this, as well as diagnose any other short circuits, for you.
Aug 09, 2012 | Dell Computers & Internet
Wont turn on
1.Plug the Inspiron's AC power cord into a power outlet and try to power on the laptop again. By far the most common cause of a laptop's not powering on is a dead battery.
2.Plug the AC adapter into a different outlet to check for a "dead" outlet. If you have the cable plugged into a surge protector, plug the cord into a different slot on the surge protector or "bypass" the surge protector by plugging the cable into an electrical outlet. If the Inspiron now powers on, replace the surge protector or have an electrician examine any "dead" outlets in the home.
3.Open the battery bay on the underside of the Inspiron by sliding the battery bay latch release lock upward and the battery bay latch release to the right. Once both latches are released, the battery bay should open.
4.Remove the battery.
5.Purchase a compatible replacement battery for laptop. Be aware that using an incompatible battery can cause damage to your computer. If you have any doubt as to compatibility, the best option is to purchase the replacement battery directly from your laptop's manufacturer.
6.Install the new battery by following the battery-removal procedure in reverse order. Once the new battery is installed, try again to power on the laptop. If there is still no power, seek professional repair advice.
I hope you find it very helpful.
Aug 25, 2011 | Gateway Computers & Internet
BOOTING PROBLEM
If the computer will not power on:
  1. Make sure the power cord or AC adapter is plugged into the computer and into an electrical outlet that is live.
  2. If it is plugged into a power strip or surge protector make sure it is powered on.
  3. Try using a different electrical outlet.
  4. Check voltage setting on power source (AC Adapters are auto switching).
  5. Perform a power reset on the computer.
To perform a power reset:
  1. Unplug and remove the AC adapter and battery, or power cable from the computer.
  2. Press and hold the power button on the computer for about 30 seconds.
  3. Release the power button and plug the AC adapter and battery, or power cord back into the computer.
  4. Press the power button and see if the computer powers up.
  5. If that does not work, try a different AC adapter, battery, or power cable and repeat these steps.
If the problem persists the computer may need service. You may need to contact Acer support.
Nov 24, 2010 | Acer Aspire 5100 Notebook
My HP PAillion ze2000 PC Notebook will not charge
I had this problem with my laptop and the way to solve it is.... guess!!
Get a new power cord!!
Dec 31, 2009 | HP Pavilion ze2000 Notebook
Laptop was working fine, but doesn't turn on anymore...
a5e3d98.jpg You might have a Loose DC Power Jack.. Or.. if you're using the same AC Power cord for both laptops that you tested, you apparently have a break(short) in the Power charging cord which is quite common...
To Test the cord..take the battery out and try to boot with just the AC power cord plugged in, If it does'nt power up, try turning and slightly twisting the plug into the port.. LOOK to see if the power light is on or flickers...
Jun 04, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
HP Pavilion zd8000 Notebook Logo
109 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
