Question about Sony XS-V1342A Coaxial Car Speaker
I have this hooked to a 600w explod amp. All i get from my speakers is bass. Can anyone tell me if this sounds like a certain problem that can easily be fixed? I have no idea what to look for, or if my speakers are blown :(.
  • 33 Answers
You amp has a low pass filter turned on. There should be a switch to turn it off on the amp, otherwise you need a different amp. Be careful, 600 watts is WAY over the v1342a's rated power of 45 watts rms. If you turn it up too loud, that amp will easily blow your speakers.
Posted on Mar 17, 2009
I have the Sony explode 1200 2/1 channel amp and 2 comp series lighting audio 10s 8ohm 900 watt max best way to hook up for loudest bass
You will have to wire subs together for a 4 ohm load. Then bridge amp (1 channel). Look on amp speaker outs to see what leads to use to bridge. Run positive and negative to one speaker then use a jumper wire from that positive and negative to the next speakers positive and negative
Sep 28, 2016 | Sony Car Audio & Video
How do i wire these sony xs-ld106p5 10" sub they have four terminals i never seen this. i have a sony xm-zr1252 2channel amp 800 watts. im bridging them im only using one sub.
Dual voice coil. Positive from amp to either positive on speaker. Same with negative, then hook the opposite positive on the speaker to the negative on the speaker with a short wire.
Mar 23, 2011 | Sony XSLD106P5 Car Speaker
I hooked up 1 10" type r to my 600w sony xplode
How many ohms is the speaker? You have the amp bridged going into the sub? You have the negative of one side hooked up to the negative and the positive on the other side hooked up to the positive?
It says that it is bridgable at 4 ohms. What about the input? Set your stereo about half way up. Then turn your amps gain up slowly until it is where you want to listen to it normally. Not to loud. Then when you turn it up it isn't too much.
But it sounds like you have way too much power for one speaker. Especially a ten. It takes two tens to equal one 12.
Dec 17, 2010 | Sony Car Audio & Video
Hi need some help instaling audio system on my bmw e39 525tds,got fuel shockwave 800 watt 3 oms subwoofer,2 JBL gto936e speakers and 2 sony tweeters and toxic tx-600 amp,can you tell me what wiring i need...
Walmart or a Specialty Audio Shop would carry a basic wiring kit for your job at task. As for the additional amp, thats your personal preference. If the Toxic Tx-600 AMP is a 600w amp, then I would say that is decent unless you're looking to get tickets for sound violations.. if you live in a city.
Jul 26, 2010 | JBL GTO936 Coaxial Car Speaker
Car audio
If you are asking if you can have a kenwood amp hooked up to your Sony Head unit then yes it would be compatable.
Jun 02, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
2 sony XS-L102P5 subs, sound great with deep bass but cones chatter when I hit them real hard
There is a possibility that you may be overpowering or under-powering your speakers with the amp you are currently using or are playing notes below the specified range of "Hz" of the subwoofer causing the sub to sound distorted or as you would call it "chattering".
If the speakers range is 130hz-45hz and your playing notes at 30hz and dont have it tuned at the crossover either on the amp or the stereo to suit the subwoofer, the speaker will try and play the note regardless and will cause the cones to move beyond its range and may cause it to slap the magnet which can damage the subwoofer if consistently played that way. Please let me know if this solved your problem..
Nov 15, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I just bought 2 12 incch explodes the xs-l126p5 modle and i have a 1000 watt explode amp xm-1652z modl. in a bandpass box. it dont sound the way i expected to. if you can help...
Did you have it hooked up by a professional or did you (or someone you know) do it. If a shop/pro didnt do it make 100% sure everything is hooked up right. Increase the size of your power wire from your battery to the amp. Check your gain settings on the amp. If the vehicle you have this in has a trunk (not a hatch back), position your speakers against the back seat facing you as your putting them in the trunk. If none of this works, buy bigger speakers and more power!
Jun 15, 2009 | Car Audio & Video
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Voice coil
I'm sorry to tell you but it sounds like you may have put to much bass at a decent power rating through them and there not designed to be replaced. The whole speaker needs to be replaced. Do not use it as you are running a risk of shorting the circuitry in your radio or amp if the impedence is off from the blown speakers and can burn it up also.
Oct 17, 2008 | Pioneer TS-A6980R Coaxial Car Speaker
Sony XS-GT - Burrrrrrrr Noise
It's likely that the cone is damaged, which isn't repairable. However, another problem I've seen with Sony speakers comes when the tweeter pod becomes loose on its mount. To check this, look at the bottom of the speaker magnet. In the center of the back plate, there should be a small screw. It might be hiding under a sticker. Try tightening the screw, if possible.
Jul 15, 2007 | Sony XS-GT6936X Coaxial Car Speaker
Sony XS-V1342A Coaxial Car Speaker Logo
102 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
