Question about Locks & Locksmithing
I have been burgled andthey took all of my keys. I have a whitco glass liding door and whitco security sliding door and was wondering if it was possible to replace these locks or if it will be too cifficult. I have another set of keys for these doors.
  • 10,865 Answers
Hi. Your lock smith can replace any lock set for you. Since the keys were stolen I would definitely change the locks and do it asap, or find some other way to lock the doors. Once again your local locksmith can advise you. J.
Posted on Aug 01, 2010
Freelander rear door window
The glass slides down slightly before the door is opened and stays down slightly until locked shut. This is to stop the glass from popping out when the door is slammed shut.
I would check for corrosion in the rear door panels.
Feb 05, 2018 | Cars & Trucks
Water gets in between the double oven door glass
I took my door apart and dried the glass with a towel. Once the screws are out you should be able to get two the double glass by sliding them out one at a time. I don't know what kind you have but this worked on mine as well as on my oven door. Best wishes.
Feb 22, 2013 | Ovens
Between glass dirty on kenmore glass top range
the door must be removed from the oven and taken apart
Oct 23, 2011 | Kitchen Ranges
Hello i am cleaning my parkinson cowan cooker and i have took the gill door off and i cant put it back on, just wondering if you have instrouction please? thankyou
Position the glass between the metal plate and the white plastic handle contraption and secure with 4 screws. This is not very stable so hold the glass securely.
Pull the grill door forward 4inches, place the glass assembly with the lugs at the bottom in the corresponing holes on the grill door.
Move the top white handle and glass thingy towards the top of the grill door.
The secret to how this works is to make sure the sticky out things with holes in at either end of the metal plate/glass/plastic handle go under the lip of the grill door.
Place the remaining unattached to anything 2inch wide metal plate above the lip.
All the holes will line up. The screws screw into the affore mentioned sticky out things with holes in.
Thats it.
If you by any chance want a new website look at this.
Nov 06, 2010 | Parkinson Cowan SG553 Dual Fuel (Electric...
How do I realign the passenger side window?
WINDOW GLASS REMOVAL
NOTE: Window glass must be operable in order to remove door assembly carrier. Any malfunction that prevents the window (manual or power) from being lowered must be corrected before proceeding.
  • Remove door trim panel.
  • Pry out sealing plugs in door assembly carrier to gain access to window glass securing bolts.
  • Lower window until window glass securing bolts are accessible.
NOTE:
If the power window motor is not working it can be renmoved to allow the window to be slid down.
  • Loosen window glass securing bolts and carefully press glass securing clamps apart.
NOTE:
If glass is being replaced due to breakage, remove door assembly carrier and remove broken shards of glass to prevent rattling noises in door.
  • Carefully lower the window regulator.
  • Lift window glass up and pivot forward, starting at the taller end of the glass. Pivot forward towards the direction of the side mirror.
  • Place removed window glass in a secure location.
WINDOW GLASS INSTALLATION
  • Slide forward part of window glass into opening and pivot glass downward, reversing the removal proceedure.
  • Raise window regulator until window glass securing bolts are visible in access holes on door assembly carrier.
  • Gently press window in the direction of the door latch or highest part of glass and tighten securing clamp bolts.
  • Remainder of installation is the reverse of disassembly.
  • Check operation of window before final installation of door trim panel.
TIGHTENING TORQUE
Window glass securing bolts...........10Nm (89in-lb)
Jun 25, 2010 | 2000 Volkswagen Beetle
I locked my keys inside and was wondering if its possible to get in through the trunk and if so how do I do so? Its a 1995 Bmw
slide a foot ruler or any metallic strip between the drivers window glass and the outer door wall somewhere above the place where the lock is. If you hear a click sound you have opened the door lock. I have seen cops do it while towing away wrongly parked cars in LA.
Feb 21, 2010 | BMW 530 Cars & Trucks
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Nov 15, 2008 | Kenmore 33169 Gas Single Oven
Locks & Locksmithing Logo
191 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
