Question about Lexmark P4350 All-In-One InkJet Printer
Copier When I copy pages, it prints document with a white/blank line across entire vertical page about an inch from the edge.
  • soaraway Jun 15, 2008
    I have the same problem. When I scan something there is a vertical band about 1" wide at the left-hand edge on the image and printed copy. This seems to be a bad contact somewhere in the scanner lid (the problem comes and goes, and tinkering with the strip connectors accessible at the back of the printer when you take the access panel off around the USB socket provides a temporary fix). Unfortunately I can't get the lid apart to check the connections inside: can anyone tell me how to do this, or suggest an alternative cure?
  • 4 Answers
Pls check cartridge and clean it then checked
Posted on Jun 13, 2008
Copier is not connected to PC. Stand alone. Vertical line on copy
To determine if the line is caused by the cartridge, try printing a test page. Not sure of your model, but there should be a menu setting to print a configuration page. If that configuration page prints out clean, then there is likely debris in the scanning area of the document feeder. You should be able to locate the debris by lining up the vertical line with your feeder. If you could reply back with the model of your Canon device, we can help you a bit more. Alternatively, you should be able to pull the cleaning instructions from the manual for your copier.
Dec 27, 2015 | Canon Office Equipment & Supplies
Thin vertical line on copies
Tara, if the ink levels are ok, try clean and allignment functions from the tool menu. Use CLEAN UNUSED PAPER.
Mar 24, 2014 | Canon PC-940 Black and White Copier
All documents have dark vertical lines printed across them
you can change the drum unit. line will disappear after this replacing.
Apr 17, 2011 | Canon imageRUNNER 3030 Black and White...
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Printer leaves white vertical lines on document
I dont know what kind of copier you have but white vertical lines are virtually always caused by a dirty charge corona.There is usually a little plastic handle, blue, green or grey, that cleans the charge corona.pull it out ONCE, push it back in and try another copy.If you have an operators manual, it should have instructions for cleaning the charge corona.Good Luck, O'scope
Mar 27, 2009 | HP Office Equipment & Supplies
Error code F2-42
Are the lines horizontal or vertical? DO you get lines on B/W copies (black and white) also? If you try to copy a blank white page do you get the lines? Does the toner / lines wipe off after the copy comes out? If the toner wipes off after the copy comes out you have a problem in the fusing unit ( the hot area that fixes the image onto the page). If the lines are vertical then you have something inside the device that is dragging across the page as it goes through the device. If the lines are horizontal then you it could be the drum cleaning blade, the transport blade, or charge roller. The noise could be that one of the blades are bouncing. It could be that a gear is worn. Please give more info on the problem to better help.
Dec 31, 2008 | Sharp AR-BC260 Color Copier
Samsung SCX-4521F All-In-One
If the lines only appear when using the top feeder, then theres probably white-out or something on the thin strip (called a slit glass) of glass on the left of the large glass.
If it appears when you put a document on the large glass, then it is another problem.
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Lexmark P4350 All-In-One InkJet Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
