Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Dishes in the bottom rack staying dirty
Bosch 24in sgs45e02
Looks as if bottom swing arm could be blocked
If so, how do I clean it
  • 4 Answers
Take off the arm and poke the blockages back into the jets then shake them out of the central pivot hole.
Remember, the drive jets (Which are at the end and make the arm turn) are the most important to keep clean.
Posted on Aug 09, 2010
Bottom water sprayer not spining
If the dishwasher won't clean dishes, check the lower wash arm assembly. If the lower wash arm isn't getting water, all of the dishes in the lower rack will come out dirty. Check to be sure the lower wash arm assembly spins freely. Also check to be sure the little holes in the lower wash arm aren't clogged or blocked.
Aug 28, 2014 | LG LDF6810ST Stainless Steel Built-in...
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Bottom rack pots and bowls dont get clean
Probably blocked spray arms is the cause of the unit not cleaning properly. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 26, 2010 | Bosch Dishwashers
Dishes, glasses on the top rack dont get cleaned. The bottom rack is fine. What may be the problem?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | KitchenAid 24 in. KUDS25 Built-in...
SHU43C06UC dishwasher cleans dishes on bottom rack but leaves dishes on top rack dirty
your top spray arm is blocked and not rotating,remove it from top basket and thoroughly clean it paying particular attention to the holes right at the ends these are angled to drive the arms round if they block up the arms will not rotate.
Nov 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top Dishes not coming clean
Clean ot replace circulation pump.
Clean or replce hoses
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Top rack remains dirty
spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
Jan 26, 2008 | KitchenAid 24 in. KUDK02CR Built-in...
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
207 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
