Question about Polti Vaporetto 2400 Canister Steam Vacuum
Polti vaporella forever 980 steam generator iron - when I pour water into the top it is not flowing through to the reserve tank at the bottom. I have cleaned it all out but this has made no difference. The water still sits on the top and so I daren't switch it on as the tank at the bottom is empty. Any suggestions? It is about 1 year old. Thanks!
    Habit-Forming:
    New Friend:
  • 73 Answers
I would make sure the hose from the top to bottom is absolutely clear
Posted on Oct 05, 2017
2 Suggested Answers
  • 7 Answers
SOURCE: I have a polti steam
It needs descaling just like a kettle we buy little tubes of descaler which you just put in where the water go's
Posted on Jan 17, 2011
Testimonial: "Thank you, I didnt have any descaler and thought maybe bicarbonate of soda may do the trick? however will get some descaler."
Heats up ok but no steam when temperature reached
Water indicator light keeps flashing and bleeping even when iron is full ,this is a brand new iron.
Sep 26, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti vaporetta comfort steam cleaner...no steam
if you put two much water in it it wont steam
Dec 26, 2012 | Vacuums
I have a polti steam vaporella iron, it is struggling to get the steam through and when it comes it is in bursts and splatters out gunge.
Jan 17, 2011 | Vacuums
Steam builds up but does not come out of the iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jan 19, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
I cant unscrew the filler cap for my polti 950
I had the same problem with the 2400 model, because the filller cap is a safety cap it thought there was pressure in the tank so wouldnt unscrew just kept going round and round. It had a little water it it. I switched it on heated it up then switched it off and let it cool a bit. There was a small metal bolt on the underside of the tank which I could unscrew with a alan key. This let the pressure out, I then rinsed it out with cold water and hey presto the safety value released itself. hope this helps
Jan 04, 2010 | Polti Vaporetto 2400 Canister Steam Vacuum
Thermerstat iron leeking water
heatman101
Nov 10, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti 1500 no steam just droplets of water
Before trying anything else make sure you turn up the pressure control knob in the direction of the + sign if it is turned right down you will have steam in the system and the gun will be heard to click open the flow control valve but you will not get any steam because the control screw is set too low just turn it anti-clockwise to increase the flow and your good to go .I hope this helps I have one too and I some times forget to turn up the flow and wonder why for 3 minutes then realise that during storage and manuevering it gets turned down by accident and i turn it up and all is well again.
Jun 20, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400 Canister Steam Vacuum Logo
176 people viewed this question
Top Polti Vacuums Experts
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
