Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Ignition 2006 superglide turns over but no fire on plugs
  • Anonymous May 18, 2008
    It has a shutting down problem, when you ride it a long distance. Then it cools off and restarts again. Its has a new battery, ignition system and coil and wires and spark plugs too. I had in the Harley shop now 3 times and they can't find the problem yet. Intermitting problem sucks.
    Scholar:
  • 150 Answers
Check for voltage to/from ignition system, check coil, check wiring
Posted on May 07, 2008
A 2003 Pro Street Venom ran great for years. I replaced a lot. it gets hot and the rear jug stops firing I replaced plugs, wires, coil, ignition timing, checked connections. What the French toast?
Hi, Brian and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or electronic control module or CDI box.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Rear cylinder will not run
07 SuperGlide rear cylinder misfire HELP plz Harley Davidson Forums
No Spark on Rear Cylinder Help
http://motorcycles.voobay.com/usedmotorcycles/big-dog-k9-chopper-kits/160
Jun 24, 2016 | Motorcycles
Harley 2006 Dyna Superglide pipes fit Harley 2005 Ultraglide
No. The head pipes will bolt up to the heads because those mounts are the same, but the rest of the exhaust mounts are different.
Dec 09, 2012 | Harley Davidson FLHTCUI Electra Glide...
Overheating when a/c is on
sounds like two different prblems, it should have a seperate fan for the AC, check to see if the extra fan comes on when you turn the AC on. Fireing problem could be anything from ignition to spark plugs.
Sep 07, 2012 | 2006 Dodge Caravan
Looking for drain plug 2006 superglide
The oil drainplug for your superglide is on the bottom of the transmission. The oil tank is on the bottom of the transmission. The oil drain is the plug closest to the front left corner of the oil tank. The other plug is the transmission oil drain.
Good Luck
Steve
Mar 05, 2011 | 2006 Harley Davidson FXDI Dyna Super Glide
Was riding my 2006 dyna superglide this morning. While crusing at 65 on the fwy the speedo dropped to zero bike sputtered than returned to normal. Now seems to be an intermittent problem. Chkd and found no...
Hi Fxdi_hog, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals especially the negative cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below.
Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Jan 23, 2011 | 2001 Harley Davidson FXDXT Dyna Super...
Firing Order diagram for 2006 Ford Explorer
Hope this helps. The ignition coil:
  • changes low-voltage pulses from the PCM to high-voltage pulses.
  • fires 2 spark plugs simultaneously.
  • has 3 transformers.
    • One transformer fires the spark plugs for cylinders 1 and 5
    • One transformer fires the spark plugs for cylinders 2 and 6
    • One transformer fires the spark plugs for cylinders 3 and 4
Spark plug wires:
  • carry high-voltage pulses from the ignition coil to the spark plugs.
The spark plugs:
  • change high-voltage pulses to spark at the gap, which ignites the fuel and air mixture.
The firing order is 1-4-2-5-3-6.
Jun 06, 2010 | 2006 Ford Explorer
What is the firring order for 2006 Cadillac cts spark plugs
Firing order 1-2-3-4-5-6 ------- front | 1 3 5 | of | | vehicle | 2 4 6 | ------- distributorless ignition NOTE THIS IS FOR THE 3.6L
May 22, 2010 | 2006 Cadillac CTS
2003 harley davidson dyna superglide ignition type
2003 is single fire. If you buy anew tach, it will come with instalation instructions. With a little common sence, it's pretty easy.
Apr 15, 2010 | 2003 Harley Davidson FXD Dyna Super Glide
Engine not firing, does the Dyna Superglide have an inertia switch? - Engine cut out after hitting a hole in the road.
I would first check the battery connections and make sure they are clean, and also check the battery. it sounds like you make be losing the electrical power, as that would make the ignition cut out.
Aug 31, 2009 | 2001 Harley Davidson FXDXT Dyna Super...
When i turn ignition on the speedometer shakes like crazy and then goes past full throttle and stays, what would cause this thanks. 2006 harley wide glide.
There were a whole bunch of defective speedos produced around your year. Check with a dealer or area service rep to see if your bike qualifies for a free replacement. My 2001 SuperGlide and a friend's 2004 Sporty had similar problems. Another possibility is bad wiring connection.
Apr 25, 2009 | 2006 Harley Davidson FXDWGI Dyna Wide...
Lands Phones Logo
70 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
