Question about Microsoft Computers & Internet
System properties can not show - Microsoft Computers & Internet
  • 323 Answers
Windows logo + r
Right click my computer
Click on properties
There is the system properties
If you want to know everything hardware and software on your computer
windows logo + r
type
winmsd
Posted on Aug 01, 2010
DELL Precision WorkStation 390 6GB installed but show 3GB usable
your system uses 3 gb,you havent lost anything you have 3 gb dedicated ram and 3 gb useable ram
Apr 04, 2015 | Dell Computers & Internet
Displai is not proper, it shows white display with cross white lines
If Windows hold down F8 on startup. This will bring you into "safe mode" right click on the desktop
and bring up properties. Here you can change the desktop settings. Or go under My Computer,
system properties, and bring up the device manager and change the monitor here.
May 03, 2011 | Computers & Internet
Hp xw9300 has 4gb of memory installed however the system properties only shows 2 gb of memory. the bios shows 4gb of memory
This article alnog with the possibility that your graphics card is using maybe a gig of memory may explain why you don't see the 4G memory in system properties. Of course it would be useful to indicate what operating system you're using.
http://blogs.msdn.com/b/dcook/archive/2007/03/25/who-ate-my-memory.aspx
Jan 14, 2011 | HP xw9300 Workstation PC Desktop
I lost my battery and volume icons in my notification sections when i did an update. how do i get them back?
Since you didn't mention the Operating System installed on your system, i'll just give you the instructions as a general for Windows Operating system.
Right-click the Task-Bar > Properties > Customize > Restore Default > Apply and see if any changes have been taken effect. If so, you can close the taskbar "properties" dialog box.
If not, under the "Customize" click on the right-hand side of the "Volume" and select "Show" or "Always show", do the same with the "battery". And click "Apply" and "Ok".
Good luck.
Thanks for using FixYa.
Aug 12, 2010 | Acer Aspire 7720 Notebook
Virtual memory too low
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the Advanced tab.
  3. In the Performance pane, click Settings.
  4. In the Performance Options dialog box, click the Advanced tab.
  5. In the Virtual memory pane, click Change.
  6. Change the Initial size value and the Maximum size value to a higher value, click Set, and then click OK.
  7. Click OK to close the Performance Options dialog box, and then click OK to close the System Properties dialog box.
I hope this helps you with your issue. Don't forget to rate. Have a great day!
Feb 26, 2010 | Acer Computers & Internet
Shows no local connection and yellow warning sign does not show installed on computer
You have not assigned ip to your NIC Card thus it is showing yellow warning sign. Just double click on double computer icon in system tray, select properties, select tcp/ip, click properties, assign ip address & subnet mask to that. For eg: ip address 192.168.0.2 , subnet mask: 255.255.255.0.
Oct 15, 2009 | Broadcom BCM5705 Network Adapter
When i create a new folder in c:\
Your system is infected by virus.Scan your system with antivirus.
Apr 24, 2009 | Microsoft Windows XP Professional
Need to change my ip address
there will will be a network status icon in the system tray
Click on the icon bordered in red and a window will be opened showing the status of the connection.
Click on the properties button and a screen showing you the properties of the network connection will be opened.
Under the general tab, there will be an option called , Internet Protocol (TCP/IP). Click on it and select properties. Now u can enter the required IP address.
all the best
Oct 06, 2008 | Computers & Internet
How to change background
These tabs are the only way to change the background or screen saver. The display properties are integrated into the operating system, so, if the tabs are missing, this is an error with the operating system. Start with a system restore. Keep going back until they show on the display properties. If a restore doesn't work, then you will need to do an operating system repair with your recovery or operating system disc.
Jul 22, 2008 | Acer Aspire 3003LCi Notebook
Processor slowing down?
On the system properties you will able to check your processor speed and your memory, it is possible that the other description is referring to your memory or Ram.
You can use other program like aida32 to check your computer spec or you can try the steps below.
To check the CPU speed, from the Start menu, select Run... , then enter msinfo32 .
You can also type DXDIAG then enter.
http://support.microsoft.com/kb/312104
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
