Question about Weber Genesis Silver C Grill
I have weber genesis 3 burner proppane grill. i switched it to nat.gas when it was new.the hottest it will get is 340 with all burners on high.
  • 36 Answers
When you switched it out did you contact www.weber.com
to see if this can be done on this grill. Weber is different than a lot of other grills usually their larger models they can be converted but their smaller models can not. This might be something you need to check with the company.
I know with Weber that it doesn't consist of change out the hose and a orifice they also change out the manifold.. So please check with Weber for these answers.
Thank you,
Fireplace-girl
Posted on Apr 26, 2008
I need to convert my weber genesis b to nat. gas. Have the hose. bought a replacement manifold part and installed but doesnt seem to work. STEVE 269-600-8111
Steve, you also need to change the burner(s) orifices to Natural Gas orifices. Natural gas won't work with Propane orifices.
Good luck and Happy Grilling!!
May 14, 2011 | Weber Genesis Silver B Grill
I now have a 3 burner weber gas grill and am thinking of buying a 2 burner weber gas grill - how do you use indirect cooking on the 2 burner grill - will there be one burner that is turned off under the...
Well, I personally, wouldn't want to go from a 3-burner to a 2-burner because I think Weber designed the 3-burner grill to perfection, and as you know, all you have to do is turn off the middle burner.
At any rate, indirect is harder with the two-burner because of the placement of the burners. You can try to put some 1" thick ceramic bricks directly on the flavorizer bars in the middle, or if you are using a rotisserie, put a pan under your meat.
Aug 06, 2010 | Weber Genesis Silver B Grill
Grill won't heat up above 200 DEGREES with a nearly full tank
Try replacing the regulator and hose, not very expensive and fairly easy to do. If that doesn't help, let me know.
Jul 11, 2010 | Weber Genesis Silver B Grill
Grill does not get hotter than 340 degrees
could be a bad regulator and or check for spider nests in the burner tube
Jun 20, 2010 | Weber Genesis Silver B Grill
1st of 3 burners will not light. The other two have gas flow.
blocked burner or gas injector or gas on off switch blocked
May 15, 2010 | Weber Genesis E-310 Gas Grill
Our weber grill is suddenly getting too hot... even with only 1 of the 3 burners turned on it is over 400 degrees... any ideas?
Sounds like the regulator is not controlling the flow of gas. Try this. 1. Turn gas tank and burner control knobs off. 2. Turn tank valve on VERY slow. 3. Open front burner knob on and lite grill. Wait a minute and turn on addition burners, (if needed).
Apr 27, 2010 | Weber Genesis Silver A Grill
Back burner won't light on my Weber Genesis Silver A Gas Grill
Only front burner lights (out of three) and it only has flame comming out of half of the tube.
Apr 04, 2010 | Weber Genesis Silver A Grill
Gas flowing to burners 1 and 2 but not 3
there could be debris in the carryover tube..(the open channelled pipe that connects the three burners together) alignment is also critical,
Jul 12, 2009 | Weber Genesis Silver B Grill
Weber won't get very hot
Safety valve needs reset.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait several seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and the rep walked me through the reset. All grills made after 1996 have this bypass valve.
Jun 21, 2009 | Weber Genesis E-310 Gas Grill
Weber Genesis Gold B Grill Problem
Could be partially clogged burner openings (jets).
Remove the cooking grates and the flavorizer bars. Obtain a BRASS brush (like used to clean white-wall tires) and brush the burner tubes from side to side and up and down along their entire length to remove all corrosion from the jets. Also the cross-over tube.
Before replacing the flavorizer bars and cooking grates, ignite all burner tubes and check to see the flames are all of about equal length and intensity.
If this isn't the problem, check the screens at the right-side ends of the burner tubes to be sure they're not clogged.
If the burner tubes are all clean and some don't ever ignite, the problem could be in the valves/manifold.
Jun 17, 2008 | Weber Genesis Gold B Grill
Weber Genesis Silver C Grill Logo
334 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
