Question about Canon Office Equipment & Supplies
I got a new printer couriered from Canada. The very first time i connected and tried to switch it on it gave me an error 5100. My printer is Canon PIXMA MX 320 Thanks Aman
    Scholar:
  • 166 Answers
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.Reset the printer
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
Posted on Aug 01, 2010
Canon pixma mx432 printer error 5100
I have a Canon mx432 that was new, but gave me a 5100 message that I couldn't clear. I cleaned the transparent belt that guides the print cartridges, and now it works great. I spent hours on it until I cleaned that strip - - nothing else worked
Sep 12, 2012 | Canon Pixma MX420 All-In-One Printer
SERVICE ERROR 5100 CANON I560 PRINTER HOW DO i FIX THIS?
Hi There
You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 06, 2010 | Canon BubbleJet i560 InkJet Printer
Canon mx700 error code 5100 - printhead seems to be jammed to the right following power cut - nothing to do with computer. Have switched machine off and unplugged it from mains, but will still not work...
Hi You can Try 2 things.
Next try.
Solution 1:
Solution 2:
Mar 13, 2010 | Canon MX700 Office All-In-One InkJet...
Service error 5100
Next try.
Solution 1:
Solution 2:
Feb 22, 2010 | Canon Pixma iP4500 InkJet Printer
Selphy DS 810. Shows error code 5100. I want to
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Only gave it a go
Nov 19, 2009 | Canon SELPHY DS810 InkJet Photo Printer
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Jul 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Regarding service error 5100 in canon ip1880 printer
1. Try to reset the ink counter by iptool software (sometimes it help)
2. Unplug the usb cable and then turn off and on your printer for a few times.
service error 5100 seems like indicating of mecanism exhausted or out of buffer ram in the printer. You should reduce the amount of pages to print at one time.
Good luck.
Jan 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Error 5100 on PIXMA MP470
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 19, 2009 | Canon PIXMA MP470 All-in-One Printer
Error 5100
I Have the same problem. Greece.  This is the second services and I a lot overwrought with this instrument.
Him I was deprived 2 times and now one more time will again make installation of other instrument for the time of repair.
Rather I will reverse the sale in order to I finish with problems with canon.
actlaw@ath.forthnet.gr
Nov 17, 2007 | Canon SELPHY DS810 InkJet Photo Printer
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
83 people viewed this question
old marine
old marine
