Question about Staples SPL616X Cross-Cut Shredder
Each time I use my staples SPL-616X shredder all the paper gets stuck around the blades what can I do? Do I need to put some oil on the blades?
  • 10,865 Answers
Yes you do need to oil the blades, but it is important to get the right oil. Most stores that sell shredders, like Staples Office Supply, also sell shredder oil. J.
Posted on Aug 01, 2010
Staples shredder parts
You can try cleaning it and maybe limiting shredding to one sheet at a time.
Jan 14, 2014 | Office Equipment & Supplies
Staples Shredder SPL-S302D I think I need a new
Take a look underneath where the shredding mechanism is and remove every bit of paper. It is a messy job, but necessary. When you finish, the shredder probably will function normally. Also, ignore the advertised sheet capacity and feed one sheet at a time. Stop when the bin is half full, dump it, and repeat the bit-by-bit cleaning process. I just went thorough this exercise yesterday!
Feb 16, 2018 | Office Equipment & Supplies
THE BLADES ARE FULL OF PAPER. SHOULD I TAKE IT APART AND ATTEMPT TO CLEAN IT?
In order to maintain a functional paper shredder, you should clean it out and oil it at least once a month(depending on usage) if not every time you fill it.
I would advise against trying to disassemble the actual blades to clean them out if that's what you mean by "take it apart."
What you can do is unplug the machine, lay the blades up and get a pair of tweezers and remove any large pieces of paper/shredding that might be caught in there.
After doing that you should oil the blades with any lubricant that your owner's manual recommends.
Most shredders suggest a non-aerosol/biodegradable oil such as vegetable oil.
Do not use WD-40 or other canned spray lubricants.
I've found that dripping the oil straight into the blades can be very messy so a good alternative is to lay out a piece or two of scrap paper and soak it in the oil. Then run the paper through the blades as normal.
They also sell varieties of this here: http://www.staples.com/Staples-Shredder-Lubricant-Sheets-12-pk-Shredder-Sheets/product_602400
It doesn't have to be a headache to maintain but proper care can make your shredder last a long time.
Jan 18, 2013 | Royal Sc120 Shredder
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
Gears not working. paper stuck in blades. how do I remove the casing for a Staples 616X shredder?
There are 6 holes on the underside of the shredder, corresponding to 6 screws that have to be unscrewed. One of the 6 has a gray round QC seal over it which you must break in order to access that last screw (in the center of the unit). The idea is that if you have broken this seal, then you've voided your warranty.
Feb 25, 2011 | Staples SPL616X Cross-Cut Shredder
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
HI,I NEED PARTS FOR MY SHREDDER SPL-616X. GEAR WHEEL WERE TO GET PARTS
i have the gears - my shredder has broken plastic guides but the gears look fine. i'll mail them to you if you like. Jeff
Aug 22, 2010 | Staples SPL616X Cross-Cut Shredder
I need to replace the plastic guides in a Staples
did you ever figure out where to get these guides? i need them too. jeff
Jul 22, 2010 | Staples SPL616X Cross-Cut Shredder
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Staples SPL616X Cross-Cut Shredder Logo
1,362 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
