Question about Corel DRAW Graphics Suite 12 for PC
Coreldraw 12 does not launch even on new installation of xp and coreldraw 12
  • 323 Answers
Are you receiving any errors?
Is this the shortcut on your desktop?
I would try navigating to the actual coreldraw.exe file
windows logo + r
type
coreldraw.exe
If it's anything like microsoft word you can use this
window logo + r
type
coreldraw.exe /s or /a for safe mode options.
Posted on Aug 01, 2010
Corel DRAW X6 problems
I presume you mean CorelDRAW Graphics Suite X6 and NOT technical Suite?
If nothing seems to work I would then do as follows.
1.Uninstall CorelDRAW X6 via Control Panel
2.After uninstalling X6 in the Control Panel - Go BACK to the Control Panel and uninstall "Corel Graphics - Windows Shell Extension".
3.Then go to Documents > Corel folder > Uninstall/Delete anything that says CorelDRAW X6
4.You can also go to C: > Program > Corel and delete anythign that says CorelDRAW X6
5.Repeat step 4, but choose folder called Programx86, and delete anything that says CorelDRAW X6
6.You should now have uninstalled everything that useally could disturb when you re-install from scratch.
7.NOW put in your DVD again with CorelDRAW Graphics Suite X6 - and INSTALL from Scratch.
8.You SHOULD now be able to run your CorelDRAW X6.
9.And NOW you should go online to www.corel.com and download and install Update/service pack and Hotfix for CorelADRAW Graphics Suite X6
10.It should in all normal situations work just fine on your PC with any Windows 7 version as well as any Windows 8 and 8.1 version.
11.Try to use a program to recover and view CDR files. For example, you can try this CDR Open File Tool http://www.cdr.openfiletool.com/
12.Also recommend to come to this forum. Many have useful information on the topic. http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/479-problems-with-cdr-files
Good luck and hope this helps!
Nov 12, 2014 | Corel DRAW Graphics Suite X5
After i uninstalled coreldraw 12 and installed coreldraw X5 trail, everything when wrong so i uninstalled coreldraw X5 but now i can't reinstall coreldraw any version and to other applications like...
Hi ebiau
Probably , if you have deleted coreldraw 12 via Control Panel , some files remained in the registry , corrupting current installation attempts .
Use the restore system application to set your computer back to an earlier date when everything was running smooth .
Next time you need to delete a program , use a proper tool like free RevoUninstaller from :
http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Best regards ,
fanaudi .
May 13, 2011 | Computers & Internet
When starting Corel draw 12 I recieving mesage; Valid workspace file not found at the path specified.End tag was not expected at this location Please help me
You can try resetting the workspace this way:
- Press F8 and hold while CorelDraw is launching
- accept the default workspace when prompted.
I hope this solves your problem
bye
Mar 21, 2011 | Corel DRAW Graphics Suite 12
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
I am using Corel X3 version and would like to open a file that was created with the X4 version. What can I do?
Step 1 Launch CorelDRAW Graphics Suite X4. If you don't own the software, download and install a free 30-day trial from Corel.
  • Step 2 Go to "File" "Open" and open the X4 file you want to convert into a backward-compatible X3 file.
  • Step 3 Go to "File" "Save As" and choose "CorelDRAW X3-compatible" from the "Save as Type" drop-down menu. Click "Save."
  • Feb 11, 2010 | CorelDRAW® Graphics Suite X3 Upgrade...
    If I move or delete an object the screen does not show the change
    Try resetting the workspace:
    Corrupt workspaces may lead to problems with the operability of the application and in some circumstances can prevent the application from launching. To restore default settings in CorelDRAW and PHOTO-PAINT, do the following:
    1. Hold down the F8 key on the keyboard.
    2. With the F8 key depressed, launch either CorelDRAW or PHOTO-PAINT
    3. The following message will appear:
      Are you sure you want to overwrite the workspace with the factory defaults?
    4. Click Yes and release the F8 key.
    Note: Some newer keyboards have an "F Lock" key that must be pressed first to activate the Function keys on the keyboard.
    Jul 21, 2009 | CorelDRAW Graphics Suite X4 for PC...
    CorelDraw 12 is not launching
    Try to reinstall
    if not work
    then download from internet and try again
    Apr 07, 2009 | Corel DRAW Graphics Suite 12
    Corel draw files do not open
    Try launching CorelDraw FIRST then open the file from the CTRL+O command in Corel. Let me know if this works!!!
    Mar 18, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
    Can't open Coreldraw 12 file
    convert bitmap object in lo-resolution by convert to bitmap option & than try to save the document
    Feb 26, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
    Display does not work properly when I use Maya and CorelDraw
    this is another typical vista programme compatibilty problem, even though certain drivers are provided they still don't worl well, when you run the programmes run them in XP sevice pack 2 mode, they may work better
    Nov 14, 2008 | Acer Computers & Internet
    Corel DRAW Graphics Suite 12 for PC Logo
    278 people viewed this question
    Top Corel Computers & Internet Experts
    photoshop serial
    Dan Shibata
    Dan Shibata
    Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
