Question about BenQ FP92G 19" Monitor
My screen size is long and thin for my BENQ FP92G. Please advise how I fix it. Roger Perkins
    Sergeant:
    Champion:
  • 301 Answers
Change display resolutions, go to panel control , display icon and change the resolutions , tray many options
Posted on Aug 01, 2010
How to fix my Benq Monitor which is scrolling full screens of different colours.
all modern LCDs have ONE and ONE only native screen size. since you did not tell us the model number we have to tell you maybe you are setting the wrong size. if the monitor has worked before then you are sending it the wrong signal.
Jul 25, 2016 | BenQ FP91V (Silver, Black) 19 inch LCD...
What size socket do I need to need to remove the oil pan plug for a 2000 Buick Century.
Hello ph91: My name is Roger and I will help you. The drain plug could be one of two sizes.It will either be a 13mm or 14mm sized nut. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Sep 14, 2011 | 2000 Buick Century
I press the power button it lights for a second then turns off screen does not come on
Doesn't sound good this sounds like the monitor it shot or the video card is shot If you have another monitor try it ad see if the video card is still working if it does the same thing then it is not the monitors
May 24, 2011 | BenQ FP92G 19" Monitor
What size are my wiper blades on my 1998 olds cutlass supreme
Hello tomkamy1: My name is Roger and I will answer your question. The passenger side takes a 19 inch wiper blade. The drivers side blade would be a 22 inch wiper blade. Should you need further help please just ask Please rate the answer. Thank You for using Fix Ya. Roger
Dec 18, 2010 | 1998 Oldsmobile Cutlass
My screen has gone off and won't come on at all
It may ahve power supply problem due to bad caps, blown fuse, cold solder joints. You need to open it up and troubleshoot it. Please read my guide and look at DELL albums (BenQ makes monitors for DELL).
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 28, 2010 | BenQ FP92G 19" Monitor
Benq FP92G screen blank, power lit not lit either. Tried different cables but still the same.
More likely to have power supply problem, that will be the first place to check, look to see if it has any caps with leaking/bulging tops/seal, burnt spots, shorted transistors in the backlight inverter board, cold solder joints. Look at my DELL albums (BenQ made a lot of monitors for DELL). Be real careful when removing the front bezel, you can easily rip apart the cable.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Sep 02, 2010 | BenQ FP92G+S (Black,Sylver) (Silver,...
Good day, i am trying to buy a spanner locknut wrench for a ford f 150 1989, i am having trouble finding it,the store would like a catalogue nofor the wrench
Hello ya_ahsmokee: My name is Roger and will answer for you. The size socket is 13/16. This is a standard size found on any 4 way lug wrenches sold in any perts stores. Should you need further help please just ask. Please rate the answer you received. Thank You for using Fix Ya. Roger
Oct 26, 2009 | 1989 Ford F 150
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Projector displays reverse image also has grayish purple color
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
Dec 31, 2008 | BenQ PB6100 Multimedia Projector
No signal and no picture, is it dead?
iS A LCD FLAT SCREEN EASY TO FIX. THE LIGHT FOR THE START BUTTOM LIGHTS AND THEN THE SCREEN IS BLACK
May 13, 2008 | BenQ FP757-12 17" Flat Panel LCD Monitor
BenQ FP92G 19" Monitor Logo
83 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
