Question about Samsung SyncMaster 740N 17" LCD Monitor
My system monitor gets blur within 20 to 30 miniutes ever time when i start system whats the problem ? screen is not clear,it is wide screen sumsung synmaster nnw ,please suggest me whats the problem but software things works perfectly
    Problem Solver:
  • 5 Answers
Maybe it is getting too hot? check to make sure that it has air flow around the monitor and that the vent holes are not blocked by curtains, desk, anything that could cause it not to get any cool air to the back of it.
Posted on Aug 01, 2010
Laptop LCD monitor (needs advance help) I have a Dell m5010 laptop that started to display small vertical lines from that bottom left corner going up to the top right corner. I plugged the laptop up to...
Try a different resolution in the monitor to see if that helps. You can do this by right clicking on the desktop and changing the resolution within the screen properties. If that does not make a difference, try searching for updated display drivers either through the laptop manufacturers website or its possible you have a bad controller board for the LCD screen.
Nov 25, 2014 | Computers & Internet
Tip
Monitor buying tips you should know.
Over the years monitors have transformed from those bulky CRT monitors to square LCD screens to stylish flat wide screen LCD's and now to new stylish extremely thin LED screens. On average every PC user spends at least 5 hours a day looking at the monitor. If the picture is fuzzy and not clear enough then there is a very high possibility that the eyes get damaged.
An older CRT monitor
A wide LCD monitor
A newer ultra flat widescreen LED monitor
Monitor Sizes
There are many different sizes of CRT, square LCD, wide LCD and wide LED monitors available on the market at the moment.
If you want an older CRT screen then sizes can range between 14" to about 20", they use the 4:3 aspect ratio.
If you want an older LCD screen then sizes can range from 15" to 19", they also use the 4:3 aspect ratio.
If you want a newer wide screen LCD then sizes can range from 18.5" to about 27" and even larger. They use the 16:9 if they are full HD or 19:10 if they are not ratio.
If you want a newer wide screen LED then sizes can range from 18.5" to about 27" and even larger. They also use the 16:9 if they are full HD or 19:10 if they are not ratio.
Image quality
The sharpness of the image in a monitor greatly depends on your Graphics card as well as whatever resolution you are running at. Nevertheless the quality of the monitor plays an important role.
Here are some of the tips that you should know before buying a monitor.
1. There are three types of monitors namely CRT, LCD and LED. The monitor that looks like a TV is a CRT monitor. In CRT monitors there is a Cathode Ray Tube that shoots electrons into the screen to create the image. An LCD monitor is smaller in width and consumes less power and is healthier if you are going to be spending large amounts of time at your PC. The LED screen looks the same as an LED monitor and the difference between it and the LCD is that it has a much higher contrast ratio resulting in darker blacks and much lighter whites.
3. A CRT monitor is much heavier than LCD monitor as you can imagine by it's bulky appearance. A LCD monitor is very lightweight and so is a LED monitor.
4. The distance between two adjacent pixels in a monitor is called 'dot pitch'. This is measured in millimeters (mm). Smaller the dot pitch the clearer the picture quality. Usually there are monitors with dot pitch varying between 0.20 mm to 0.27mm. Some manufacturers use diagonal dot pitch while most of them use horizontal dotpitch. The diagonal dot pitch is always longer than the horizontal dot pitch
5. Resolution of a monitor has to be considered with care. Most of the CRT monitors have resolutions of 800×600, 1024×768 and 1280x1024. The square LCD monitors have 1280×1024 and 1600×1200 resolutions. Newer wide screen LCD monitors have resolutions of 1600x1900, 1680x1050 and the Full HD 1920x1090. When the resolution is higher the images and text will appear smaller. But you can see more text and bigger pictures in the monitor with high resolution.
6. Another thing to note is the 'Refresh rate'. This rate is usually 60Hz, 73Hz, 75Hz, 85Hz. Refresh rate of 85Hz means the picture on the monitor is refreshed 85 times within a second.
7. The brightness and contrast can range between a low 5 000:1 to a high 80 000:1 in a LCD monitor and an average of 5 000 000:1 in a LED, yes that's 5 million to 1 with a LED. This just shows how much better a LED monitor is to a LCD.
8. If you are a gamer then the thing you have to look at with LCD monitors and LED monitors is the response time. If it is 16ms then this is a very bad monitor for gaming and you will experience a ghosting effect in most games and if it is 5ms then you will have an average gaming experience. What you want to get is a 2ms response time monitor, with it you will have the best gaming experience with no ghosting what-so-ever.
on Mar 06, 2011 | Computers & Internet
Picture gets blurred and then disappears.
christian204, Your unit may be 5 -6 years old, and may have developed a problem with it's internal "switch-mode-power-supply" and will need good CCFL backlit lcd monitor tech to repair it. When strange and wierd things start to occur on lcd screens the first place to look would be the SMPS. 12fixlouie
May 11, 2010 | LG Flatron MW-30LZ10 30" LCD Monitor
I have a mw monitor ,it comes on for about a miniute then goes black i can hear sound . the picture is dull switch off then on same problem. can it be the backlight?
The picture board of your monitor has developed fault. That is why the screen goes black.
The best thing for you to do is to take the monitor to a local repairer within your vicinity, because the fault is not something you can fix on your own in other not to complicate issues.
The repairer will help replace the faulty picture board and your monitor is back and better.
Take care.
Apr 21, 2010 | EMC LCD Display mw Monitor
Photos not clear on webpages
It can be the problem of your computer screen resolution. Few things to cross check with your system
1) Check the screen resolution supported ( approx. 32 bit 1024x768)
2) Supportable graphics driver.(recommended get the latest driver and install it again)
3) check the IE Text Size under view menu it should be MEDIUM
Jul 30, 2009 | HP Compaq Presario V2000 Notebook
Lg 17" moniter power disconceted after 3 or 4 miniutes & many time power not on what is the problem
check ur power connection from wall socket to ur pc.....also make sure its tight to ur screen....including all othere cables going to screen
if this not solves the problen bring ur monitor for service........could be a problem inside with power pac
Jul 03, 2009 | LG Flatron F700P 17" CRT Monitor
Image blur
You need to check that display resolution in your Display properties is set to the native resolution for wide monitor typically 1440><900 for the size you mention.
Blurred image is due to using 4 : 3 resolution setting of 1024 >< 768 on a 16 : 9 wide monitor.
Samir.
Please rate the solution and provide feedback.
Jan 02, 2009 | Samsung SyncMaster 214T 21.3" LCD Monitor
Analog Monitor problem
The problem in your monitor is SRGB
Use 3 simple steps to rectify this problem
1. Connect your monitor to another CPU
2. Change The Resolution to 800x600 32/24bit
(After 2 Miniuts SRGB will Reset)
3. After 5 Miniuts change the monitor to your CPU
Thank U
Apr 06, 2008 | Computers & Internet
Blurred picture
Have you tried lowering the Screen Resolution and Screen Refresh Rate of the PC in its Display Properties?
It could be that you PC's current settings are way above what the Samsung can handle.
Good luck and kind regards.
Thank you for using FixYa
Mar 22, 2008 | Samsung 793S 17" CRT Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
65 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
