Question about SanDisk Sansa MP3 Player
Sansa express won't start
I checked the media devices in the control panel and it said that the divice is not able to start. When i turn it on sometimes Sansa express will appear, but it will quickly go away. When i try to charge, it gets an unrecognizable symbol on the front. What should I do?
  • Anonymous Sep 01, 2008
    It Wont even pop up in the My Computer
  • Anonymous Dec 11, 2008
    I had the same problem after manually turning my computer off with the sansa still plugged in. Once I put in the micro sd card it worked and turned on. Thanks a lot!
  • 728 Answers
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work for you.
Posted on Nov 26, 2008
I was listening to the player and it all of a sudden wouldn't shut off and it wouldn't charge, after 2 days it charged and i was able to get into the files but it wont let me delete the files and says my...
When the Sansa Express keeps freezing you can RESET the device using next step:
note:
The device can be either on or off, player NOT connected to the computer:
Press and hold the Volume Up (+) and Select buttons simultaneously for approximately 20 seconds.
When the "rebuilding database" message keeps coming back, the player will need an update.
Use the Sansa Firmware Updater (works on Windows only) or go for the matching download on the forum:
http://kb.sandisk.com/app/answers/detail/a_id/446/kw/database/p/555%2C662%2C687/r_id/101834
The Sansa Firmware Updater will contain the driver for the computer to perform a firmware update on your player [ METHOD 1 ].
When downloading the driver package manually, first put the driver "StMp3Rec.sys" in the correct folder on your computer. Next start the SansaExpressUpdater [ METHOD 2 ].
During this update, connection between player and the computer is based on MTP mode, Media Transfer Protocol: Drivers and software are needed to get access to the player.
The player could also be accessed in MSC mode, seeing the player as a removable disk. How to get connection in MSC mode, see next link:
http://www.machinist-toolbox.com/SansaExpress_MSC-Mode.pdf
Manual for Sansa Express:
http://mp3support.sandisk.com/downloads/um/express-userguide-en.pdf
Support site for the Sansa Express:
http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC9nWWpkcGYqag%3D%3D/sno/0#express
May 19, 2010 | SanDisk Sansa MP3 Player
Problem to transfere recordings from sansa express to computer
the same problem with my sansa mp3 player is is showing me an mtp device but could not find any folder in pc
Nov 23, 2009 | SanDisk Sansa MP3 Player
Sansa express - turn on, "building database", then shuts off
Put In A Micro SD Card
Start It Up
It Should Work
You Can Now Safely Remove The Micro SD Card And It Should Start Up Fine
Mar 22, 2009 | SanDisk Sansa MP3 Player
My sansa e250 won't stay connected to the computer.
If it is flashing constantly, go into Start --> Control Panel --> Printers/Othe Hardware --> System --> Hardware --> Device Manager --> and uninstall either the Sansa or the MTP device. Disconnect the Sansa from the computer, and reinstall the software that came with the mp3 player.
-Tha Mp3 Doctor
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
How can i put pictures and videos on the sansa e250
The Sansa Media Converter (SMC) software is required to convert and transfer videos as appropriate to your Sansa or your microSD card.
Nov 22, 2008 | SanDisk Sansa e250 MP3 Player
Sansa m240
Go to Start --> Control Panel --> Printers and Other Hardware --> System --> Hardware --> Device Manager --> find MTP device or Sansa player, right click and either disable or uninstall (better)
Jun 27, 2008 | SanDisk Sansa m240 MP3 Player
Sansa express shows "sandisk" in the display for 5 seconds and then dies. model - BB0704UIB
Reset should work
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 13, 2008 | SanDisk Sansa m240 MP3 Player
Windows Media Player won;t sync music!
Turn off the automatic sync option - change it to manual sync, and then you should be good to go. Change to manual sync first, and then reformat.
Apr 09, 2008 | SanDisk Sansa e260 MP3 Player
MY Sansa Express, says USB malfunctioned, when connecting to PC
If you get the problem where MTP Device keeps popping up continuously, uninstall the "MTP Device" by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Oct 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa MP3 Player Logo
118 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
