Question about Schwinn Bicycle Aluminum Frame Pump
Air does not come out of bigger hole, what's wrong?
THE TRICK TO SWITCHING OVER THE OUTLET FOR THE PUMPED AIR IS BACK PRESSURE. IF WHAT YOU ARE FILLING IS COMPLETELY FLAT, BLOW INTO THE FITTING YOU WANT TO USE AND IT WILL SWITCH OVER.
Posted on Oct 06, 2012
Weedeater fl25
I did the same thing and was told i messed it up. Put it out for the junk dealer to pick it up. apparently those holes are a different size for a reason.
Feb 05, 2018 | Garden
I have a 1982 cm 450 and it will start but when I
You need to remove and clean the carbureators. Pay close attention to the jets, use a single bristle out of a wire brush to clean the hole in the jets. Just clean the crud out, DO NOT make the hole any bigger. After getting things cleaned up reassemble and reinstall the carbs.
Mar 29, 2010 | 1982 Honda GL 400
When shotting the gun the nails dont go in all the way. ive tryed raising the air pressure and adjust that littlet still doesnt shoot all the way. thing on the gun but still doesnt work
you can try to use connections with bigger holes and a hose of bigger diameter, so you have more air at the gun en less pressuredrop over the hose and connections. try first to fit the gun direct to the compressor and test if it is better.
Feb 05, 2010 | Porter Cable Cable BN125A Factory -...
Puck doesn't glide well
the problem that you are facing now is that you have made the holes to big for the fan to be able to distribut the air evenly so in turn you will need to get a bigger fan to compinsate for the larger holes, one of the things that we did to get the puck to slide alot better was to apply car polish to the table and the puck, let it dry then shine it like you would to your own car, i hope this helps
Jan 02, 2009 | Harvard Xh 7000 Hockey Table
IR 210g - using thicker paint
i dont have so much as a solution as a couple of things you can try to figure out whats going wrong.
make sure your compressor can handle 10.5 CFM @ 50psi
hook up the gun and dry spray it to check for blockages in the air supply
if the air comes through strong and constant, fill the paint hopper with water and spray until empty
if the water comes through constant, add half of the hopper with paint thinned with penetrol or floetrol
if the paint is coming out weak or spotty, make sure the vent cap is open on the paint hopper
if the cap on the hopper doesnt have a vent, try spraying with the cap off or cracked a bit.
if that doesnt work take off the hopper and check the filter for blockages.
i suggest straining all your paint before pouring it into the hopper
Nov 19, 2008 | Ingersoll Rand Hvlp Automotive Spray Gun
Move timing cover with the motor still in the car. go behind harmonic balincer
sounds like you have had a frustrating time.... sorry to add to it.... i believe the balancer has to come off to replace the timing cover.
Robert
Sep 27, 2008 | 1992 Cadillac DeVille
Schwinn Bicycle Aluminum Frame Pump Logo
249 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
