Question about Vacuums
Have Sunbeam Electric Blanket Model BL442D, Only 6 weeks Old. Has Started to flash with An E message on the control. Can anyone help me please.
EwingElect
  • 276 Answers
SOURCE: We have an sunbeam electric
Hi. If you have a double or queen size blanket, switch the controls from one side to the other. If the fault follows the control, then the control is faulty. If the fault stays on the same side of the bed, then the blanket may be faulty. Most recent Sunbeam models have 3 years warranty. Once you've checked the controls, if it's under warranty call Sunbeam Customer Service on 1800025059 option 1 to report a warranty issue.
Otherwise: if the control is at fault, a new BL0750 has a recommended retail of $75.20. Get in contact with your local Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
but if all else fails email me as I'm happy to help!
Posted on May 25, 2010
tunde007
  • 2382 Answers
SOURCE: need a schematic for Sunbeam
Hi, the schematics for the electric blanket are not readily available online maybe due to the company's policy just like some others that i know. You may try your luck by contacting Sunbeam on (800) 667-8623 to make a request for the schematics.
Posted on Oct 05, 2010
  • 383 Answers
SOURCE: The one of the controllers
I did some searching-- and I came up with this Linkedin page-- seems to have some information-- Let me know if it helped-
http://www.linkedin.com/companies/jla-home
Mack B
Posted on Jan 20, 2011
wentlanv
  • 710 Answers
SOURCE: When connecting the dual controllers
Generally, when you're putting electrical things together, you assemble first, then plug in.
Handie Andie
Posted on Mar 27, 2011
rohntech
  • 422 Answers
SOURCE: Dual control sunbeam electric blanket,
An error has occurred in your unit. Near the power or elsewhere find the reset button and press it. If you done it still error is blinking, check if you can the heater and thermostat of the blanket has a problem. Either a short or open circuit occur.
Thanks for asking.
Posted on Jun 25, 2011
I am trying to repair a Sunbeam Model T-35 radiant control toaster. Everything is working but I can't seem to get the timer control (for setting light and dark) set correctly. Is there some...
I have/had a similar problem. Here's how I fixed it.
UNPLUG THE TOASTER
1. Clean the crumbs out throughly. I removed the bottom of the toaster (6 screws) to make sure all the debris was removed. Use a soft brush. Replace bottom and tighten screws. 2. Gently brush the sensor area in the 'one slice' slot with a soft brush. 3. Remove 'darker-lighter' knob. I gently pried mine off with a small screwdriver. 4. Plug toaster in. 5. Put a slice of your usual bread in the 'one slice' slot. 6. Watch it toast. 7. When 'done' to your liking slowly rotate the control counter clockwise using a small screwdriver until the toaster stops toasting. 8. Replace knob with the pointer at the mid point (up and down) to allow for minor adjustments.
Aug 18, 2011 | Sunbeam Vacuums
Dual control sunbeam electric blanket, one side is blinking 'E' have disconnected it several times, but still nothing. It was wotking fine the night before. The other control is working fine.
Thanks for asking.
Jun 25, 2011 | Vacuums
The one of the controllers for the electric blanket keeps flashing an "e". The other controller is fine. We switched controllers and the same thing happened. We have unplugged the blanket for...
Mack B
Jan 20, 2011 | Vacuums
Our westpoint home electric blanket, model 950, flashes 8 on one unit & can't be turned off. ELECTRIC BLANKET!!
Try pressing the power button and boost button at the same time. Then a C will flash and the setting you had it on before will show up. I think that was caused by pressing the boost button.
Dec 28, 2010 | Vacuums
I received this electric blanket as a gift and it will not heat up on either side. There is no light on the controls when I turn the blanket on. I need my blanket to work - it's like brand new!
Appears to be that the power is not getting to the temperature controllers. Suspect a problem in the wiring between the wall outlet (if not the wall outlet) to the temperature controllers. Look for broken plug at end of cord or a break in the cord between the plug and the controller. Last, you may have to look at the connections inside the temperature controller the power cord goes to in order to see if there is something loose inside. But do this with the blanket unplugged.
Sep 18, 2010 | Sunbeam Vacuums
How do I find the model number on my sunbeam heated blanket?
The model number should be on the back or bottom of one of the temperature control units.
Sep 15, 2010 | Sunbeam Vacuums
We have an sunbeam electric blanket model BL 0750 We dont seem to be able to programme it to heat up. Control lights are flashing
May 25, 2010 | Vacuums
Vacuums Logo
59 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
