Question about Samsung Digimax D73 Digital Camera
Having taken a photo last night the camera turned itself off but seems to have frozen with the lens stuck out. any suggestions
  • 3,230 Answers
Well lens errors are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism. Follow the below steps to do a try to correct it -
1. Remove the batteries from the camera, wait a few minutes. Put a fresh (or new) set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
If further you have the same problem - it means there is a gear-motor alignment of the lens which moves in and out with the help of motor (it need some repair). This part is replaceable at an authorized Samsung Service Center.
Good Luck!!
Thanks for using FixYa!!
Posted on Aug 01, 2010
My sons kodak easyshare cx6230 only takes black/blank images. Screen works, but all photos taken are black. Suggestions please?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 06, 2011 | Kodak EasyShare CX6230 Digital Camera
My Canon PowerShot A620 will turn on, but the lens doesn't come out, then it beeps six times then says "E18" in the lower left corner of the LED, then the camera turns itself off. I can see...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
By the way, I also own an A620, great camera! Hope you have luck with the above.
Jun 25, 2011 | Cameras
The screen of the camera works only for setting and menus, but for shutting photos the screen is black. No more photos could be taken. I seems to be taking photos but all of them are black. But I heard...
And here you go, this should help. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 29, 2010 | Canon PowerShot S2 IS Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
I have a Kodak Easyshare model dx5430 digital camera (5mp). It has worked like a champ for years. Last night I was at an event when the image display went dark at picture 31. All preceding photos were able...
May 01, 2010 | Canon PowerShot A75 Digital Camera
My Kodak Digital Camera has a screen frozen. I was deleting a pic when it froze,I need help NOW. Also the flash light is flashing green.
This just happened to me last night. Literally, the EXACT same thing. Here's the sollution:
Wait 'til your camera has run out of chage, it will then turn off. The camera lens will still be sticking out, though. Once it has turned off, take your charger, plug it in, and then charge your camera. Once the charger is actually in the camera itself, it will turn on and resume its' normal mode. :)
Jun 05, 2009 | Kodak EasyShare V1003 Digital Camera
The lens is stuck
my daughter sat on ours while it was on and the lens wouldn't retract. I tried the banging repair suggested for a stuck lens. After quite a few tries, it got the lens to retract when turned off but it wouldn't stay out when on, so i grabbed the lens and gently pulled it all the way out while it was on and it worked! (phew!)
Sep 15, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
My camera keeps switching itself off!
I ordered some new batteries for it before posting my problem ,a dn after using the new batteries, the problem no longer exists. It seems that my batteries were so run-down that they just couldn't power the lens anymore or the flash at times
Sep 05, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Lens stuck
Hello, I have read other forums that suggest that quite literally rapping or swatting the unit on its bottom half can actually solve the problem and get things going again. I am going to try it with mine. I too have a stuck lens. Here is a link that details this crude method: http://www.pechorin.com/m/2005/09/10/Sony_DSC_MVC_camera_repairs-245400-11.html
Aug 05, 2007 | Sony Cybershot S650 Digital Camera
System error
This is fundamental break down and may not be repairable. Check out th Nikon Web site technical support
Jun 17, 2007 | Nikon Coolpix 4300 Digital Camera
Samsung Digimax D73 Digital Camera Logo
96 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
