Question about Home
Why soap is called toilet soap - Home
  • 699 Answers
Interesting question!
There are many type of Soaps some of which are Industrial and extremely dangerous cleaning agents.
A 'toilet' soap is a mild soap, often coloured and scented, used for washing oneself ... in a washroom which usually has a toilet!
'Toilette' is the french word for washroom/bathroom.
Hope it helps!
Posted on Aug 01, 2010
Dropped cap to Aquakem in toilet--it seems to be inhibiting macerator-won't flush. Hope the problem isn't worse than that. Is there anything that we can try before puling the toilet, or is that it?
Time to remove the toilet. I had the same experience with a plastic soap dish - plugged the toilet completely. A rented property to boot.
Oct 09, 2017 | Home
What hygiene items do I need to take with me on my camping trip?
There aresome basic hygiene items that you should remember when packing for your campingtrip:
  • Soap/cleaneryou can use as soap/shampoo/dish cleaner
  • Toothbrush/toothpaste
  • Portabletoilet/ toilet waste bags/***** funnel (for women)
  • Toilet paper
  • Lightweightcamping towel
If you havespace, add any items that you really feel you can't live without for a fewdays.
Aug 02, 2012 | Camping, Backpacking & Hiking
I am looking for a Greewich (Delta) satin nickel wall mount soap dish and can no longer find any vendor who sells them.
I've found several different styles & manufactures of satin nickel bath hardware at Home Depot and Lowes. Soap dishes,towel rods,toilet paper holders and even matching toilet flush handles.
Jun 22, 2011 | Liberty Hardware Bath Unlimited Greenwich...
Leak bubbles out from top vent thru sponge barrier - just wondered why?
I had the same issue before and called Saniflo. They told me that when the pumps are assembled at factory, they use soapy water to test the unit and see if it leaks. By flushing the toilet with plain water only a few times will eventually get rid of the soap residues inside the pump.
Jun 09, 2010 | Saniflo & Saniplus& Macerator Pump
Toilet works fine,but drains for sink and shower stall drain very slow
hello there:
sounds like you may be having a partial block in you're drain lines do too paper and things being flushed down the toilet you may need to go to the outside of the house and find the cap on the drain vent and use an industrial snake and run threw the drain lines to get ride of the clog this should solve the problem you should be able to rent one from ace....hope this helps you out thanks
May 29, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My Whirlpool Cabrio washer is backing up into and overflowing my toilet every once in a while during the spin cylce. But today, the washer was not running and the toilet overflowed. The toilet is located...
Your problem is not with the washing machine. I suspect that the drain line for your toilet is obstructed further down the line than your snake can reach. If you have a clean out riser to your sewer system, flush the toilet while someone else is watching the flow past the clean out. I would say that renting a sewer line snake at a tool rental like Home Depot would solve your problem. Good luck
Mar 05, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
My toilet overflowed and I had some water in the washer when I turned the valve off on toilet it stop overflowing and when I turned the washer on spin cycle it emptied the toilet. However, there is still 5...
The emptying of your washer caused suction through the sewer and cleared the clog of the toilet for you. Odd but possible. You do not have sewage in your washer though. Run through rinse cylce to clear out remaining water.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hansgrohe 41533 wall mounted soap dish install
I had the same problem with a Hansgrohe set screw on my toilet paper holder. Thought an allen wrench would do to open it but it does not work, I had to use the end of a pointy dinner knife to coax it out, might have also used a flat edge glass repair screwdriver also to get it out. It almost look as if it was "stripped" in the opening. I'm now trying to find a replacement set screw and came across this page. Hope that helps.
Apr 15, 2009 | Hansgrohe 41535000 Axor Uno Toilet Brush &...
Spam filter test
My toilet is a hotel toilet. Would you like about 50 shampoo bottles and soaps? your friend, Steve
Nov 09, 2008 | Home
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
