Question about Morphy Richards Jet Stream 42271 Iron
Heating up but no steam when depressing the switch ?
As above +red light going out when temp achieved,water container filled to the mark, no deficiencies with the hose or elecs.
    Genius:
  • 1,478 Answers
First remove the water tank, take out the cartridge, fill to the line with tap water, replace the cartridge and slid back the water tank into the steam generator. Plug in, press the power button and wait. This is one disadvantage of these irons as you have to wait about two minutes for it to 'power up'. A green power light will flash while it is heating up and will remain on to indicate it is ready. Select your heat setting; one, two or three dots the same as most irons on a dial on the iron itself under the handle. Next select how much steam you want. This is done by pressing a button on the back of the base unit which has three red light indicators with one, two or three little pictures of some steam indicating your choice. Level one produces 22.5grams of steam per minute, level two produces 45g/min and level three 90g/min. By way of comparison a conventional iron gives about 20-40 g/min steam maximum. It is also possible to have no steam if required.
The next stage also differs from a conventional steam iron. You need to depress the steam button which is located on the underside of the handle where your fingers would naturally be. This button needs to be held down for about a minute to clear the system of air. While this is happening there is a clicking noise which is rather strange at first. When it is ready the clicking will fade and steam will be coming out the plate. It is now ready to go.All this needs to be done each time before you start ironing which is fine if you have a lot to do but not if you only want to do one thing quickly for work or school.
While you are ironing, the steam button on the underside of the handle has to be held down all the time that you require steam.
Posted on Aug 01, 2010
Steam not working on iron then lots of water pouring out of holes
fill water chamber with vinegar and let it sit for 24 hours.
empty vinegar - fill with distilled water - turn on and press the steam button to clean the holes in the plate of mineral deposits which accumulate from using tap water. after a few shots of steam all should be clear - empty and refill with distilled water and it should be good to go.
May 08, 2012 | Tefal Pro Express GV 8120 Iron
How to empty water form iron when finished
Unless you are not going to use the iron for a long time, especially if you use distilled water to fill your steam iron, I would really not bother.
However, if you do want to empty the iron after using it, you have a couple options:
- With the iron still hot, very carefully, use the cleaning function or the 'shot' of steam until no more steam is generated above the sink preferrably.
- With the iron unplug/NO electricty: very carefully tip the water out from whe filling hole above the sink - be aware that the water will remain extremely hot for a long time so avoid splashing water on yourrsel!
Hope the information is useful.
Sep 23, 2010 | Black & Decker D2030 Iron
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Mar 23, 2009 | Irons
Rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Jul 22, 2008 | Rowenta Commercial Garment Steamer - White
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Tefal Pro Express Steam Generator Iron
Once you have filled up with water and always just below full line, if your model has one, you need to press the "reset" or "restart" button on the back end of the generator (the end furthest away from the water container). Also, do be sure to regularly descale as advised above otherwise the water/steam can't get through.
Jan 21, 2008 | Irons
Morphy Richards Jet Stream 42271 Iron Logo
381 people viewed this question
Top Morphy Richards Irons Experts
Mack Baxter
ray gallant
Are you a Morphy Richards Iron Expert? Answer questions, earn points and help others
