Question about HP Photosmart C3180 All-In-One InkJet Printer
Scanning the scanner won't work... i press the start scan/reprints button and the green power button keeps flashing...everything els works...copier..printer...just not the scanner
  • 2 more comments
  • Pancho 1 Apr 29, 2008
    the scanner doesn not work... i press the start scan/reprints button and the green power button keeps flashing...everything else works...copier..printer...just not the scanner why. What can i do to scan?
  • Anonymous May 10, 2008
    the scanner donĀ“t work
  • sdlew May 21, 2008
    Using Mac OSX, attempting to scan directly from the printer. I cannot scan from my PC. The only response is the flashing power button.
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    1.What is the Operating System?
    2.Are you trying the scan from the PC or directly on printer by pressing scan button?
    3.when you try to scan from PC, what is the error message?
    Thank you
Same thing happened with me. I just went to hp's website and downloaded the new driversdrivers.
My scanner works perfectly fine now. (i have c3180 and macosx)
Posted on Apr 03, 2010
Machine will not scan, blue light only blinks.
I have had this problem before also. What I ended up doing was shutting down my computer, turning on the scanner opening it all up so you can load it and ensure it is hooked up to the computer, restart the computer, open the program itself but then scan by pushing the flashing button on the machine, not using the program. I am not sure if yours will work this way or not but good luck.
Jan 03, 2013 | Fujitsu ScanSnap S510
When i press scan the green power button just flashes and nothing happens.
Iam gicing two solutions- depends on your flexibility you can scan.
Solution 1:
Please try this procedure instead of press scan.
Download picasa 3.8 from
  1. Make sure everything is connected and turned on!
  2. Put the photo on the glass of the scanner - face down
  3. In Picasa, click 'Import'
  4. Click the arrow for the drop down list of devices. You should see your scanner listed ... select it
  5. Now you will see a screen that depends on your scanner. There should be an option to 'Preview'. Click that.
  6. You should now see your picture, there may be some settings you want to change here, but if it looks OK then
  7. Click the button to Scan
  8. When it's done scanning, you're back at the standard Picasa Import screen. Click Import all.
  9. Select a folder to put it in. I made a folder called 'Old Photos' for the first one, then, for each subsequent scanned photo, I selected that existing folder from the drop-down list.
Solution 2:
please download HP Deskjet Full Feature Software and Drivers from the below link
select your operating system then download full feature software and drivers and install .
then It will work when you press scan.
Even if it is not working there may be some hardware button problem...may be...
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 09, 2011 | HP Deskjet F2210 InkJet Printer
The scan function won't work on my HP Deskjet F4280. When I press the scan button, all that happens is the light on the power button starts flashing. Any assistance would be much appreciated.
the scan function won\'t work on my HP Deskjet F4280. When I press the scan button, all that happens is the light on the power button starts flashing. Any assistance would be much appreciated
Dec 03, 2010 | HP DeskJet F4280 All In One Printer InkJet
Having opened the top pannel to clean lens, my Laserjet 5000N came up with this error message. "printer error 52.0"
52 is a scanner error, the scanner here is actually a rotating mirror assembly that 'scans' the laser right to left. (as the paper moves top to bottom)
Make sure you did not smudge the lens or move it too far in any direction. Gently use a clean q-tip or equivalent to 'reclean' the lens.
Then, power down, count to 10, power up.
Same error?
Power down. Find green checkmark button, power up, when memory starts to count, press and hold green checkmark button until ready, data, and attention lights all flash. Release Green checkmark button, display should say "Select Language".
Press Down arrow once, display should say "Cold Reset".
Press select and wait for a reboot to complete.
If you still have the error, then you have a physical problem and will need a repair tech to fix it.
Aug 31, 2010 | Computers & Internet
My HP PSC 1210 does everything except scan. The
try scaning from computer. i mean dont press the scan button -on printer but rather use some application on your pc to start the scan. you could test with office document imaging software.
Feb 13, 2010 | HP PSC 1210 All-In-One InkJet Printer
When i press the scanner button, it does not work, the power button starts flashing right after i press "scan" other then that, the copier and printer work, can someone please help me?
have you installed printer software in your system and you connected the printer to system ( after connect the printer to your system press the scan button it will scan the document to your system ) all printer software like hp photo smart hp solution center ........
now try and post your problem ...........
Dec 17, 2009 | HP DeskJet F380 All-In-One Printer
Green light at front keeps flashing. wont scan
Hi, this might help you:
try to download the drivers and other software from or some other site and try to reinstall everything.
if you can't find them then search something like: 'hp scanjet 3200c drivers' on google or other....
I hope this is useful, and greets.
Oct 20, 2009 | HP ScanJet 3200C Flatbed Scanner
How to start a scan? when i press the scan button,the power light flashes green,but nothing happeneds?
If u find this kind of prob then u have scan the required stuff by using ur scanner software if u r using hp then go for controlpanel click on scanner and camera devices and follow the on screen instructions to scan the required one hope this will solve ur prob.
Jul 07, 2009 | HP Ruggedized DC Car Adapter for HP...
Dec 09, 2008 | Umax PowerLook 2100XL Flatbed Scanner
I am trying to scan a photo. I put the photo face down on the scanner of my HP Photosmart C3150 All-in-One then push the button for start scan/reprints and nothing happens. Can you help me?
I had purchased a new computer that ran on Windows Vista. I was able to go onto the HP support and found out that the scan button would not work because the printer was purchased before Windows Vista operating system came out even though the printer and copier part worked fine. HP support offered two solutions and the one that worked for me was to:
Click Windows Icon
Choose Programs
From Scanner or Camera
Nov 03, 2008 | Office Equipment & Supplies
HP Photosmart C3180 All-In-One InkJet Printer Logo
258 people viewed this question
Ben Johnson
