Question about Compaq Armada M700 Notebook
I can't format...
I cannot see in the boot menu the cd-rom because it should be the 1st boot..
    Sergeant:
    Champion:
  • 301 Answers
Go to bios settings , when you started appear the setup options , chosse that option and go to peripherals and you can chosse the boot sequence, save and exit
Posted on Aug 01, 2010
I am using to reinstall a window from recoveru disk which i made when i buy Acer Aspire 5610. It start from the begining that code 0xa000000c. What shoult I do PLz
it wont work...(recovery CDs mostly dont work)
you need to have a WinXP boot and install CD...as many system files of windows are not re-installed by the recovery cD
get a Win XP CD(a bootable one)...i.e. original WindowsCD(even a pirated CD may work)
insert the CD in the CD drive and re-start the PC....(BIOS) must have boot seq set to CD ROM as the 1st boot drive...(if not then do it)...press F2, Del, or F10 key when PC starts...go to the boot menu and chose the boot seq and select CD ROM as the 1st boot drive...then save and restart....
let it boot from CD...
now you can repair the OS
Reg
Mar 12, 2011 | Computers & Internet
What are the steps of formatting toshiba tecra M9 using window XP Recovery Disk?
If you are using the original XP Recovery Disk for Toshiba, you have to set your first boot to CD/DVD Rom from our Bios setting or use the 1st boot Function Utility when booting up.
If your 1st boot is your CD/DVD Rom, the Recovery Disk will boot up, and your just follow the wizard to finish the OS installation back go the default setting.
Hope it helps.
Oct 16, 2010 | Computers & Internet
System running slower that normal, and freezes randomly.
1st you go BIOS setup and change the Boot Order or Boot sequence.
  • Select Boot From CD Rom.
  • Then Save the setting .
  • Insert the Window XP Cd in the Cd Driver .
  • when the computer start again .
  • It will boot from Cd Rom.
Then you follow the instruction and install the windows.
Mar 13, 2010 | Soyo Dragon P4I845PE Barebone
My laptop won't boot from cd
to reset the BIOS, there is a small battery somewhere in your computer. if you unplug it for 3 seconds, it will reset the BIOS. I RECOMMEND THAT YOU DO NOT TRY THIS! get a service professional. If this doesn't work you might need to get a new laptop.
Dec 29, 2009 | Toshiba Satellite A105-S2712 Laptop
I connot open the windows.windows showing NTLDR
this could be the computer trying to boot off a USB device plugged into the computer.Check that you don't have any USB devices plugged in. and no CD in the drive. then reboot the computer.
Dec 09, 2009 | Acer Aspire One PC Notebook
Replaced HD and CD Rom drive, PC will not boot to disk, Do I need to format HD 1st. before loading OS?
Hi Get to the bios screen using F8 or F9, change the first boot device to CD ROM/DVD, then insert a bootable disk into the CD drive and try installing the OS first by completely formatting the HD during installation Win XP and higher OS editions give you the option to partition the HDD Hope this resolves
Nov 05, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Help
you need to configure your bios setting by doing so, your 1st boot device must be cd rom. how? upon power-on you need to press the delete button to appear the bios then configure setting as stated above then save and exit. note, cd winxp must be inside cd rom to start your format operation.
Nov 25, 2007 | ASUS A8N-SLI Motherboard
Compaq Armada M700 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
