Question about Ahead Software Nero 7 Essentials Suite Full Version OEM
Nero startsmart essentials cannot open how can i open this?
    Sergeant:
    Champion:
  • 301 Answers
If you cant open , reinstall again
Posted on Aug 01, 2010
Unable to copy music to cd by using nero7
First you need to locate your music/audio. If it was downloaded from Limewire/Frostwire the default location would be C:\Documents and Settings\**Your Username**\Shared
You can also access your music/audio through Limewire/Frostwire, by going to your Library, then highlighting a file that you want to burn and press explore. This will open the folder containing the highlighted file.
Alternatively use the search to search for something you know is in the folder you want to access or eg. search for the extension of the music/audio you want to burn.
First it may be worth mentioning that there are two ways of burning audio in Nero 7. Using Nero Express or Nero Burning ROM (The original Nero program). I find both very simple to use, but prefer Nero Express, so That's what I will use here.
First open Nero StartSmart:
Pressing add is not necessary. You can also open folders outside of Nero Express, and then you drag and drop the same way.
You can make mp3 disks using Nero Express as well. Just choose make Data Disk instead of Audio CD in Nero StartSmart. The only difference you will see is that instead of minutes you will be adding size (MB)
In case you run into playback issues when using Nero Express, then you have two options. You could try using Nero Burning ROM. Raaf explains here how to do that with Nero 6, but Nero 7 is very similar:
Burning a (audio) CD from your MP3's (Windows)
Another way is to run a tool called CD/DVD Drive Speed (can be found in Nero StartSmart under Tools, where you let Nero burn test disks for checking the best speed for this type of disk.
Aug 03, 2012 | Ahead Software Nero 7 Essentials Suite...
New code
If you have purchased a Nero 7
If you have a trial version you need to buy the serial number.
Enter your serial number as follows:
Launch Nero StartSmart.
To do so, double-click the Nero StartSmart icon on your desktop.
If you do not have a shortcut to Nero StartSmart on your desktop, open Nero StartSmart as follows:
Click Start in the Windows® Start menu.
Then select Programs-Nero 7 Premium-Nero StartSmart
• Nero StartSmart will open.
Click the "Nero" logo in the upper left corner of the Nero StartSmart window.
• The Nero ProductSetup will open.
Click the Licence icon on the left side and then the Add button.
• The Nero ProductSetup window will open.
Enter your Nero 7 serial number into the input field and click the Add button.
• Your Nero trial version is changed into the full version of Nero 7.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | Ahead Software Nero 7 Essentials Suite...
How to prepare a cd
Well, that depends on what kind of cd u want to prepare.
If you want to prepare a data cd, then
open nero startsmart(im assuming u do have nero as this question is in Problem with nero 7 category) open the data tab
choose data cd/dvd(whichever u prefer)
select files to be added
and then follow the instructions on screen
Oct 08, 2010 | Ahead Software Nero 7 Essentials Suite...
I do not have serial number for nero 6.6.1.4
Hi, I don't know if you thought this is a Nero support site or if you want some help finding out how to get the Serial Number for your program. I'll help with both if I can.
Your Nero program has a "startsmart" utility built in. Try this if it is installed:
1. Launch Nero StartSmart.Do this from the desktop using the startsmart icon, or go to start, programs, Nero 6 and then startsmart.
2. Nero StartSmart will open. Click the "Nero" logo in the upper left corner of the Nero StartSmart window.
3. The Nero ProductCenter will open. Click the "serial number” tab to see your serial number.
4. Your serial number is displayed in the window on the right.
If your copy of Nero is registered you can go to their web site and use their SN finder. https://register.nero.com/eng/login.asp
At Nero, click My Home tab and then the My Serials entry.
Registered Nero serials window opens.
Click the Display link behind the product name of the registered serial number.
Your serial number will be displayed.
Sometimes this works even when it has been uninstalled.
1. Click "Start" in the Windows start menu.
2. Click the "Run" command.
3. The window "Run" will open. Enter "regedit" in the "Open" text field and click the "OK" button.
4. The registry window will open. You will find your serial number on the left side in the navigation tree.
Go to the path: HKEY_LOCAL_MACHINESoftwareaheadNero - Burning Rom_Info
and double-click the "Serial" entry.
5. Your serial number is listed in this location. It looks like this:
1A2x-xxxx-xxxx-xxxx-xxxx-xxxx
This is Nero's list of free utilities that help solve common problems. http://www.nero.com/enu/support-nero6-tools-utilities.html
If you are looking for a bootleg SN, we can't help you. I hope that one of these methods helps solve your problem. Thanks for visiting Fixya.
May 09, 2010 | Ahead Software Nero Express 6.0 (NERO6OEM)...
I don't my serial number
If you have the box or cd case for the game, check there first. If not, and you have the game installed, do the following.
This is the customer service link where you can get help getting your SN: https://register.nero.com/eng/login.asp
If your copy of Nero is registered you can go to their web site and use their tools.
If your copy of nero has not been uninstalled:
2. To do that, double-click the icon "Nero StartSmart" on your desktop. If you do not have a shortcut to Nero StartSmart on your desktop, open Nero StartSmart as follows: Click "Start" Programs"-"Nero 6"-"Nero StartSmart".
3. Nero StartSmart will open. Click the "Nero" logo in the upper left corner of the Nero StartSmart window.
4. The Nero ProductCenter will open. Click the "serial number” tab to see your serial number.
5. Your serial number is displayed in the window on the right. Please write down your serial number.entry.
If that doesn't work, try your registry: Sometimes this works even when it has been uninstalled.
Go to the path: HKEY_LOCAL_MACHINE\Software\ahead\Nero - Burning Rom_Info
You can help me give better answers by letting me know if this was helpful or not. If you have a minute, please rate the solution so others that have your same problem will get the best answers. Thank you.
Dec 26, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Free serial number nero startsmart plz
Download nnero start smart serial number RAR archive here >>
Unpack RAR password: "nero123"
What the serianl number for nero6
should be listed on the box or cd label. If you downloaded it the place you downloaded nero would give you the seriel number.
Dec 20, 2009 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Problem using Nero Startsmart Essentials to burn audio CD
its a issue with ur writer lensc, it not write properly
Nov 21, 2009 | Computers & Internet
How to download nero startsmart essential
its not possible to download but you need to buy an original version of nero as we hate piracy
Jan 21, 2009 | Motorola Mobility Mobile PhoneTools 3.0...
Having trouble opening my file and videos
This could be due to a problem in the file association which got changed when u uninstalled nero. Right click on the file you need to open and select open with option. From that list select some other application which could open that file. For eg if it's an mp3 file select media player and select the always open with this application option. Lemme know whether that works. Don't forget to rate the solution. Regards
Jan 06, 2009 | Dell Red Hat Enterprise LINUX WS Version 3
Ahead Software Nero 7 Essentials Suite Full Version OEM  Logo
89 people viewed this question
Top Ahead Software Computers & Internet Experts
Martin Murray
Tony
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
