Question about Dell Inspiron B130 Notebook
Laptop will not boot up completely, shows backdrop and screensaver, can't get task bar at the bottom to pop up.
  • Dell Master
  • 4,924 Answers
This is a condition caused by a damaged windows....To be exact some of the system files that are responsible with the desktop appearance were damaged or radically changed...
First point the mous at the bottom of the screen to see if the task bar is not set to autohide...if nothing gets on ..try to right click on desktop and than properties,,,and on the themes choose the windows that you use...and ok ..and see if the desktop is getting back ....If the result is the same the only fast solve is to reinstall it using the recovery cd ..or partition ...or a boot-able cd with the operation system ...cause if it is not getting back after that it means that it was completely and irremediable damaged..
Posted on Aug 01, 2010
How to lock the task bar when it does not showing on screen
It may be set to auto hide. Try moving your mouse cursor to the edge of the bottom screen. If it doesn't show up, try the other three edges of your screen.
Once located, right click on the task bar and choose "Properties" from the menu. On the window that pops up, simply uncheck the auto hide option. If the bar is already on the bottom edge, click on the "Lock the taskbar option." If not, drag the bar to the edge of the screen you prefer and then lock it.
Jul 04, 2016 | Acer Extensa Computers & Internet
Show task bar on computer
What is the operating system? For Windows 7 and older, move the mouse down to the edge of the screen and see if the task bar slides up. If it does, right-click on it and from the scroll down list, select properties. From the pop up settings box, remove the check mark on the Auto-hide the task bar box.
Now the task bar should be ever present at the bottom of the screen.
Sep 03, 2014 | HP EliteBook 8560p Notebook
Win xp laptop won't run programs fro Start menu
Either your system is really corrupted, or you've got a virus. The only think that comes to mind is to go to task manager, find explorer.exe and click End Process, then click File > New Task (Run...) and type explorer.exe. This will reload explorer and possibly fix the issue.
Apr 05, 2014 | Dell Inspiron Computers & Internet
Start tast bar disappears
Right click (hit right mouse button) on task bar and click to lock task bar and uncheck hide task bar. If you cannot right click on time before it disappears move pointer to the bottom of screen and it should reappear. Than follow above steps. If all else fails restart computer clicking on the F8 key repeatedly until start menu comes up , choose safe mode and when the computer starts up your task bar should remain in place, follow above steps to unhindered it permanently and reboot the computer it will start back up in normal mode and your task bar should be "fixed"
Feb 05, 2013 | Lenovo ThinkPad T410 Notebook
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
Pc powers up but appears not to complete startup and the task bar does not show also desktop shows only a wall paper
it is hanging on a start up item. boot into safe mode and use the start>accessories>run then type mscofig. under general tab select " selective start up" and make sure origianl boot configuration is checked.
Nov 04, 2010 | MSI Computers & Internet
Task bar is missing on bottom of screen after pc wakes up.
mine does this with windows 7, right click on desktop and open 'personalize' then open 'taskbar and start menu'
From here choose to move your taskbar location to the side of the screen and click apply. it should return, then just tell it to go back to the bottom.
Sep 18, 2009 | Dell Studio XPS 435 PC Desktop
No icons or start bar along the bottom when it's turned on
your infected with virus. try to remove hardrive and and put it to other pc scan it with updated antivirus. if you dont want to loss your files.if the files is not that important then you can format your unit using your windows cd.
Feb 09, 2009 | Microsoft Windows XP Home Edition
PC Display after booting
Okay this is a flaw with XP. what you need to to is when that happens. Wait for the screen to load and press Ctrl+Alt+Delete and that will bring up task manager. Under the file button on the top right hand corner and select New Task (Run...). Then the run box opens up and type in the box EXPLORER.EXE that should show the task bar and shortcut icons. If you need any more help just ask me.
All The Best,
RCF
Aug 30, 2008 | Microsoft Windows XP Professional With...
Boots halfway and dies
One from all problems can be:
Hdd problem or power suply
If u have another hdd change it and try
Let me know if u got help?
Nov 27, 2007 | Dell Inspiron 1100 Notebook
Dell Inspiron B130 Notebook Logo
23 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
