Question about Philips Televison & Video
I have a philips sru5101/17 universal remote control and im trying to get the manual with the codes to programme my tv.
0807 0022 0020 0422 0122 0222 0322 0322 0002 0520 0919 0521 0621 0709 1516 1017 0430 0247 0901 0402 0408 0109 0210 0310 0715
Posted on Feb 07, 2011
Need code 2 rca remote for Phillips tv
These are the Philips tv codes! 006,007,010,011,013,016,033,035
Dec 26, 2014 | Televison & Video
Tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 | Televison & Video
Philips universal remote code for 19 inch sharp TV
Please go to below website you can get the codes to programme your remote.
1. Location
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.896948c.jpg
Thank you
Sep 19, 2010 | Philips Universal PH301S Remote Control
Have a sony universal remote model RM-V401 trying to set code for a phillips tv
Procedure to programme Sony universal remote RM-V401 to philips TV are
1. Turn on the component to be programmed.
2. On the remote control, press the SET button.
3. Press the appropriate component button for the component being set up.
4. Using the number pad, enter the component's manufacturer code.
5. Press the ENT button.
6. Point the remote control at the component.
7. Press the POWER button to verify operation.
Code for philips TV are 011 043 056
Thanx
Aug 06, 2010 | Philips Televison & Video
Remote control phillips cl032
1. Location
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.a76bc94.jpg
Thank you
Jul 29, 2010 | Philips Magnavox Learning Universal Remote
I have a philips universal remote i need the code
Please go to below website you can get the codes to programme out remote.
Please follow the below instruction.
1.Location
2.Select your remote
3.On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
4.Select the device you need to programme and the make of the device you will get the codes.
Thanx
Jul 25, 2010 | Philips Universal PH301S Remote Control
Philips Universal Remote Codes to program an Orion TV
hi! i have here a couple of codes for your orion tv! just try them, 1023, 1033, 1107, 1382, 1383, 1511, 1382, 3213, 1383, 3202, hope this helps!!!! goodluck!!!
Jun 07, 2010 | Universal Remote Control Philips Pronto...
Philips universal romote pm435s code and manual
try those codes: 0023, 0223, 1112, 1912, 1515
Oct 14, 2008 | Philips PM435S Remote Control
Philips universal sru 3030
Manual is available at following address.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philips&dv=universalremote&md=sru303010&kw=&st=&ar=&dt=&so=&pg=2&file=others/philips/sru3030-manual.zip
Hope that helps,
erch.
Mar 17, 2008 | Philips 483521917703 Remote Control
Televison & Video Logo
699 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
