The Honeywell Programmable Heat Pump Thermostat CT3611R is not adjusting the temperature to a cool setting. Cool air is coming out of the vents however the temperature on the thermostat remains the same and the room does not feel any cooler.
If your problem has existed since the begining of installment it could be a return/ thermostat placement problem. if the return is to close to any supply vents it will run like that and your thhermostat will read like that
Posted on Apr 25, 2008
FocusPro TH5000 will not cool
Make sure the thermostat is set to "cool" mode. Make sure the thermostat is wired correctly and has fresh batteries in it. Check both the thermostat end and the air handler end of the wires. If All this checks out, the problem is most likely in the air conditioner, not the thermostat.
Mar 29, 2014 | Honeywell TH5220D1003 FocusPRO 5000...
Tip
The Honeywell TH811U1003 thermostat is a universal programmable thermostat that...
The Honeywell TH811U1003 thermostat is a universal programmable thermostat that gives you electronic control of 24V AC heating and cooling systems. It also has the capability to be used on 750mV heating systems
One of the best features of this thermostat is it’s big clear backlit display. The current temperature, the set temperature and the time of day are displayed at all times. Simply touching the screen also activates the back light feature.
This thermostat has a menu programming guide the helps you through the process of setting up your schedule. You are able to select multiple days and customize the thermostat for any kind of unique schedule you may have. This thermostat also let’s you take it off the wall and still be able to program it. This lets you watch TV and program it at the same time.
There are built in backups that will hold the time for you if the power goes out. This t-stat will also update for daylight savings time. There are HOLD features that allow you to modify your program and hold it and then go back to the original.
Change reminders that are built in include the air filter, UV light, humidifier service and of course the batteries of the thermostat. The blower of you furnace can also be programmed to run extra to help increase the air quality in your home.
If you decide you want to know the outdoor temperature you can purchase an additional sensor and then hook it to you thermostat. The outdoor temperature will then be displayed on you thermostat. This feature also gives you the capability of using the sensor to monitor indoor temperatures remotely.
This thermostat will keep you very comfortable as the variation typically in temperature from set point is less than 1 degree F. The thermostat after a period of time learns the characterizes of the way the house or building heats and cools and then adjusts to get the most efficient operation of the heating or cooling system while maintaining a very close temperature tolerance.
By changing a few of the parameters in the thermostat this can be can be configured for either single stage conventional heat/cool systems or any single stage heat pump system.
Specifications of the Honeywell TH8110U1003 Thermostat
  • Description: VisionPRO Touchscreen 7-Day Programmable 1 Heat/1 Cool
  • Conventional and Heat Pump Thermostat
  • Application: Gas, Oil or Electric; Heat Pump; Millivolt
  • Programmability: Universal Programming from 7 Day to Non-Programmable
  • Changeover: Auto or Manual
  • Color: Premier White
  • User Interface: Touchscreen
  • Switch Positions (System): HEAT-OFF-COOL-AUTO
  • Switch Positions (Fan): AUTO-ON
  • Power Method: Battery or Hardwired
  • Terminal Designations: R, RC, C, W (O/B), Y, G, S1, S2
  • Dimensions (in.): 4 9/16 in. high x 6 in. wide x 1 1/4 in. deep
  • Mounting: Horizontal
  • Electrical Ratings: 20 to 30 Vac
  • Frequency: 60 Hz. 50 Hz
  • Setting Temperature Range (F): Heat: 40ª F to 90ª F. Cool: 50ª F to 99ª F
  • Setting Temperature Range (C): Heat: 4.5ª C to 32ª C. Cool: 10ª C to 37ª C
  • Differential Temperature (F): 1ª F
  • Differential Temperature (C): 0.5ª C
  • Stages: Up to 1 Heat/1 Cool
  • Outdoor Sensor: Yes, optional outdoor or indoor remote
  • Remote Sensor: Yes, optional outdoor or indoor remote
  • Sensor Element: Thermistor
  • Currents (Heating): 1.0 A running
  • Currents (Cooling): 1.0 A running
  • Currents (Fan): 0.6A running
  • Operating Humidity Range (% RH): 5 to 90% RH, non-condensing
  • Comments: Selectable to and Heat Only or Cool Only
  • Features: Screen lock
on Jan 15, 2010 | Hardware & Accessories
Tip
Th811u1003
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Specifications of the Honeywell TH8110U1003 Thermostat
on Jan 15, 2010 | Heating & Cooling
I installed a honeywell CT87N thermostat. The
the burners light? if the burners dont light than it's working right the blower on the furnace comes on with the a\c
Jun 19, 2010 | Honeywell Electronic Programmable...
Installed a honeywell rth7500 series thermostate, no air
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
May 29, 2009 | Honeywell Electronic Programmable...
Honeywell YTH9421C1002, heat pump puts out cool air in heat mode
You have the stat programmed incorrectly or wired incorrectly there are alot of settings for installers in that stat and all of them have to be set correctly
Apr 05, 2009 | Honeywell Programmable Thermostat Heater
Heat pump that just blows cool air
is the condenser operating? what is the outdoor temperature? A heat pump is a cooling system with a reverse gear, most reversing valves which make this possible fail to the heat mode so it is not likely to be the problem. You should have either gas or electric back-up heat. If you switch to emergency heat do you get warm air? Really need to find out more to make an informed guess at your problem, the simple stupid would be is the circuit breaker to the condensing unit possibly tripped or shut off?
Dec 18, 2008 | Honeywell Programmable Thermostat Heater
Honeywell thermostat for (heat/AC pump) #T874G1246 Temperature levers for heat and cool are only adjustable in tandem, ie: can not adjust them independently.
your heat pump can only do one thing at a time. its either cooling, heating or off. you have no need to adjust set points individually.
Dec 10, 2008 | Heating & Cooling
Heating & Cooling Logo
157 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
