Question about Mackie SRM-450 System
Need a replacement tweeter for mackie srm 450 where can i find one
  • 4,234 Answers
Go to the link below to either locate a dealer near you for the part or to contact Mackie directly for the part. Please note that the diaphragm may be available as a separate part. Do you need the entire tweeter or just hte diaphragm?
Dan
Link: http://www.mackie.com/support/
Posted on Jan 12, 2011
3 Suggested Answers
SOURCE: Mackie SRM-450 tweeter distorts sound
I wish to change access to the diaphragm
Posted on Jun 16, 2010
  • 4234 Answers
SOURCE: hello there i have a
The most common cause of this is a blown horn. A replacement can be ordered from Mackie directly. Remove the screws that hold the plastic horn in place. At the rear of this part will be the tweeter assembly that unscrews from the horn. This needs to be replaced.
Another possibility is that the tweeter driver has broken from the horn itself and is inside the cabinet. Remove the horn and you may find that the aluminum part has broken. Replace the horn which comes with that part and you should be fine.
Dan
Mackie srm 450v2 tweeters sound low
You have to disassemble the cabinet with a 18 inch long screwdriver first in order to get access to the driver, then remove the 4 allen nuts on the plastic that covers the diaphragm and proceed to change the diaphragm, most of times they start to sound low because they break the titanium in peaces or in a small portion.
Aug 06, 2013 | Mackie SRM-450 System
Tweeter problem
Since this is a bi-amplified speaker there's only 2 possibilities here:
*Tweeter amp or,
*Tweeter diaphragm.
You can test the diaphragm as a starting point using an ohmmeter to verify tweeter coil impedance, let me know if i can help more.
Mar 21, 2012 | Mackie SRM-450 System
HOW MUCH IS A REPLACEMENT SPEAKER AMFLIFIER FOR MACKIE 450 SRM V2 AND LABOUR
Be prepared to buy another instead of sending defective unit for a fix, in fact better to buy another model but NOT the V2...
Oct 13, 2011 | Mackie SRM-450 System
Mackie SRM 450, the main speaker has stopped working but the tweeter is OK, there is nothing coming from the speaker at all, no hiss, or clicks.
It could be 2 things:
*Blown Speaker or,
*Fried power amp output stage of woofer, since this speaker operates as a bi-amplified system it has separate amps for woofer/tweeter...
Aug 17, 2011 | Mackie SRM-450 System
The top part of the mackie speaker isnt working. all that is working is the big bottom part, and the sound sounds like the bass is the only thing coming out.
The typical cause of this is a blown tweeter or the tweeter has broken off of the horn and fallen inside the cabinet. Remove the screws from the horn and carefully remove the assembly. Try the speaker at low volumes to see if you hear any sound at all. Next, remove one of the wires and using a 9Volt battery quickly touch the 2 leads on the tweeter. If you don't hear a click, the tweeter needs to be replaced. Contact Mackie service for a replacement.
If you hear a click, then the problem is in the crossover or amp and further investigation willbe required.
Dan
Jun 05, 2011 | Mackie SRM-450 System
Hello there i have a mackie srm 450 speaker system and im not getting any high end tweeter sounds just bass only what coule be the problem manay thanks Paulie
Dan
Aug 12, 2010 | Mackie SRM-450 System
Mackie srm 350 tweeter is dead cannot find any UK parts servicesa that will provide either a new diaphragm/coil ot even the whole tweeter
I found that Stan at Surrey amps was able to supply a tweeter for a srm 350. But you need to let him have the full part number on the tweeter as it seems they have changed the design on the tweeter at one point ( or more ) in the manufacture.
phone (0)208 8730927
www.surreyamps.co.uk
regards Peter
Mar 16, 2010 | Bob Mackie SRM350 Main / Stereo Speaker
I'd just order a new diaphragm and see if that's the problem before any other dismantling. If that's not the problem, I'd take it to a certified repair shop. The fact that it's still working but not producing certain frqs,tells me you won't be able to see the problem with the naked eye.
Feb 19, 2010 | Mackie SRM-450 System
What kind of tool is needed to open mackie srm450 speakers. I need to replace tweeter.
12" phillips screw driver total of 16 or 17 screws on back, then open like a **** its easy!
Jul 29, 2009 | Mackie SRM-450 System
Mackie SRM-450 System Logo
493 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
