Question about Car Audio & Video
I cannot get my head unit to turn on - Car Audio & Video
    Genius:
  • 1,035 Answers
Hi. May i know the brand and model of your head unit?
Posted on Aug 01, 2010
  • 12 more comments
  • dgkingford Aug 01, 2010
    the unit is a kdc-pm339
    it is a kdc-mp339
    my telephone number is: 0439593034 can you ring me on this number please?
  • Angelito Rabago
    Angelito Rabago Aug 01, 2010
    Thanks forthe quick response. Problem could be general wiring of the headunit going to the main source. Have you check you fuze box if the fuse forthe radio is ok? i provided you link where there is basic instrcution on how to connect the power of the unit to the main. Please click here.
    All the best!
    i have done all that and there is power getting to the unit up to the faceplate but the faceplate will not turn on
  • Angelito Rabago
    I see. I got that problem also with my Pioneer DEH 7450. There could be a problem somewhere between the metal strips of the face plate going to the head unit. Mine is, if you press down where the metal strips are located i am getting the graphics onthe screen. So what i did is, i adjust the metal strips that would reached to the contact ofthe head unit. After doing this, problem is solved. if you are not getting any response when you press donw the face plate then there could be a problem with the face plate itself. By the way, how old is the unit?
    about 4-5 years old i think as it was my brother who installed the unit and we had it working friday afternoon up until my father put the front drivers seat in but now it will not work
    i tried your suggestion but it did not work even then so i am at a loss as to what is wrong with the unit
  • Angelito Rabago
    I see. Your father might accidentally bumped the face plate that caused mis-alignment to the main unit. Try my suggestion first for this happened to Pioneer also. This is a common problem with head units with detachable face plate.
  • Angelito Rabago
    changing the car seats are not actually related to the issue. There is no reset button on the unit. So i guess you need to have it checked to the manufacturers technician. Since unit is turning on and the issue only is there is no response from the face plate.
    there is power getting to the unit but the faceplate is what turns on the unit and there is no power coming through the faceplate as the areal would be going up/down if the unit was switching on
  • Angelito Rabago
    try adjusting the power strips from the face plate by using a needle and gently pull the strips in an outward direction. Make sure that the strips are kept aligned when you pulled it. then test again.
    it had connctors and i tried your suggsetion and not a whisper of life in the faceplate
  • Angelito Rabago
    I guess you need to bring the unit to a repair electrical technician and have the face plate checked. There could be something wrong or is loose inside the face plate or possbile blown out IC chip that needs replacement or for possbile re-alignment.
KDC-MP4032 head unit wont turn on
hi, seeing that your kenwood showed up "protect" you may have an audio circuit/amplifier fault within the unit. try resetting the unit to see if unit comes "on" again. if the unit comes on and protect flashes again, then you definitely have an internal audio circuit fault. if not then check all power connections(yellow and red wire voltages, as well as ground connection), as well as the condition of the face pins!
May 31, 2012 | Kenwood KDC-MP4032 CD Player
I was attempting to take my head unit out, and i assumed i had to use removal keys and whilst trying to use them to remove the head unit i dropped one of the keys into the unit. i diddnt think this would...
remove the unit from power for about 15 min, that should clear the settings then plug it back in. if it still shows protect then there is a short in one of the power or ground wires.
Mar 08, 2011 | Kenwood Kdc-mp445u Car CD / USB/ MP3...
Cant get sound in dvd mode only in radio mode
PS: Check if you car has remote wire or anterna wire.
Details below.
A relatively common problem is installing an amplifier with a factory head unit or other head unit without a remote turn on wire (or a burned out circuit). So the amplifier doesn't stay on 24 hours a day you need a way to turn it on and off remotely. Hence the term "remote turn on wire". Almost every aftermarket head unit has a remote turn on wire. Some manufacturers call it a power antenna wire. But regardless of the label all it does is output a positive 12 volts when the head unit is turned on. It should be noted that some head units have both a remote turn on wire and a power antenna wire. It's important to use the right wire for your amplifier and other electronic equipment. In the case of both remote and antenna wires the power antenna wire will only output 12 volts when the radio is on. If you were to connect your amplifier's remote terminal to the power antenna wire then you would only get output from the amplifier with the radio. When you switch to CD the amplifier would not work because the head unit turns off the power antenna wire when the radio is section is not active.
There are several ways to get your amplifier to turn on and off remotely even if your head unit does not have a remote turn on wire. The cheap and easy way is to run the amplifier's remote terminal off of a switched accessory wire. This is the wire that your head unit uses. It is only powered when the key is in the accessory or run position of the ignition switch. When you shut the car off the wire loses power and the head unit and amplifier will both turn off. Your amp will be on when your car is on and off when you car is off. If you don't want the amplifier to always be on when the car is on you could wire a simple switch inline with this new remote wire. Normally you would leave it on so that it turns on when the head unit is on. But if you wanted to turn the amplifier off you could flip the switch to off which would stop the flow of 12 volts to the amplifier's remote turn on terminal.
Baadaye Mo
Oct 26, 2010 | Clarion VZ709 Car DVD Player
Where is the power switch, or how do you get the power running through to get blue light to turn on?
There is a terminal marked REM it's between the + 12 volt and Ground terminal.
The REM terminal needs a power source connected to it to turn the amp on and off. It's usually the blue remote wire coming off the head unit.
This turns the amp on when your head unit is on and turns the amp off when the head units off.
May 21, 2010 | Pioneer GM-3100T 300W 2-Channel Amplifier...
Deh-9300 remote on wire ground
There is an internal relay that switches the amplifier remote turn on from ground to 12VDC when the ignition (ACC) wire is applied power.
The internal relay (inside the radio) is faulty and must be repaired.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 30, 2010 | Pioneer GM-7100M Car Audio Amplifier
Head unit blown out possibly ????
souds like the wires on the speakers is the wrong way round or the speakers are ****
Dec 14, 2009 | Alpine SPS-600C Car Component System
Cd shuttle ejects when power to head unit is turned on
Hi Adam,
Since you've been trying things for so long, you may not mind another, unless you've tried it already.You'll need someone to help you.
Try using a volt meter on the main power to the changer. (If the changer is din mowered only, this can't be done) and when toy power up the head unit by ignition or other method, read the voltage on the main power wire (yellow?). Tell me what it shows. Also, the "turn on" wire for the unit is usully in with the data cable to the unit, and won't be able to check that.
Also try to read BOTH the acc AND the power wire on the head unit while turning on.
When you read the voltges, make sure that you use the ground ON THE CHASSIS of the componant that you are checking. "Maybe" you have a voltage variance like you said d to a weak ground at one of the units? I'm just troubleshooting as I would if you had brought it to me. Let me know again. Thanks.
** Note- Have you actually reset bothe the head unit and changer?
Larry T
Winona Lak, IN
Jan 27, 2009 | Blaupunkt Louisiana DJ32 Cassette Player
Amp shuts off when switched from radio to cd
your amps rem wire is hooked to the power antenna wire on your head unit and so when you turn off the radio you would nolonger need an antenna so it powers down and would lower the antenna.Depending on the head unit you should have one output for the power antenna and one for the amp rem......If your head unit doesn't have the rem output you can wire it to the switched wire that powers your head unit but keep in mind the amp will stay on while you have the key in acc or run position even if your head unit is off.
hope this helps!
Jan 16, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Turns on 1 out of 4 times?
The problem might not be with the amp. You will need to check the "remote" output from your head unit at the amp end using a voltmeter. It should be ~12.5 volts dc when the head unit is turned on. If there is no voltage when the head unit is turned on, then the problem is not the amp. The head unit may be bad or there may be an intermitant short somewhere in the remote wire.
You can test the amp by removing the remote wire and connecting the remote input directly to the +12v terminal. Use a short scrap of wire. This will (should) manually turn on the amp. Don't forget to return the remote wire to the remote input or the amp will never turn off.
A friend of mine had his remote wire shorted to ground once after he replaced his head unit. Turns out when he slid the new one into the dash opening he pinched the remote wire against the chassis. Frustrating but an easy fix.
Sep 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
