Question about Dell Dimension 4600 PC Desktop
The speacker is not working, give me back this diver
  • 487 Answers
Hi, try this link for your sound driver: http://support.dell.com/support/downloads/devices.aspx?c=us&cs=19&l=en&s=dhs&osl=en&SystemID=DIM_P4_4600&os=WW1
Posted on Aug 01, 2010
How to get the stacktic out of the speackers
I could give advice if you give me the model number and confirm the brand.
Mar 23, 2012 | RCA Televison & Video
Hi, The blue light temporarily comes on like it is going into protect mode and then shuts off. I do not hear the relay click. I measured the input voltage and it is at 12v and when the power is switched...
hi ill try helping .
protect is something that stops ur amp from blowing , so there is somthing melted or speacker wires touching inside box , speackers could be blown an it some times is in the speacker itself ,but there is something because i have a 600watt sony with 2 10 clarions an it hits an the voltage reads almost 13 an stays when i turn it on hope this helps a little
Jul 12, 2011 | Hifonics Brutus BX 1205D Car Audio...
I have no diver to run the boad so plz give me solution to give diver
Go to the manufacturers website and download drivers.
Aug 23, 2010 | Computers & Internet
Same HP/pavilian speackers and low soung from gx280
save your polks,go to the nearest truck stop store and purchase a set of little loud mouths their called,i guanantee you will hear those.
Jun 15, 2009 | Dell OptiPlex GX280 PC Desktop
Kdc-519 install in 93 mustang
if u have cut the factory harness, then u may have cut the power on wire for the factory amp
Jun 07, 2009 | Kenwood KDC-519 CD Player
How do i wire 6x9 from the back shelf to the head unit using new wire where do i wire it on the head unit?
if you are going to place the speackers into the rear shelf than you can run your wires along the underside of the shelf,then towards the back of the rear seat, then run it down the length of the seat, when you reach the bottom you will need to try to pry the backrest portion seat foward just enought to get the wire thru to the front, then you will need to get either a phillip or slotted screwdriver, open the back door and at the bottom unscrew the trim from the bottom of the door way,run wire thru do the same with the front door, then run wire behind the trim around or near where the emergency release handle is at, run wire behind instrument panel towared your deck. when you go to wiring up the deck and speakers check on the deck to see if it has a wiring diagram on it if not: most decks come as follows ( white wires front right ,blue or purple rearl left, brown front left, grey rear right red is + black is - yellow is constant +( always on so your deck is able to stay programedwith your presets and audio settings and clock)one single blue or purple wire is the remote for your ampif the colors dont match the ones on your deck then hook up your deck to the power only when the deck comes on go ahead and set your speackers to only the rear right speacker and take your wires from your speacker and touch them to the wires on the back of the deck, once you hear the audio coming thru go ahead and mark this as right rear or rr then using the same speaker change the settings to rear left speacker and do the same as with the other one mark it rl and do same for front speackers
Feb 28, 2009 | Pioneer TS-A6962R Car Speaker
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
Speacker problems
cheak sound card settinsg for 4 ch 5.1 output or in audio main menu ok
Feb 01, 2008 | Logitech X-530 Computer Speakers
Speackers
Hello 6423,
The RX-664VBK is capable of having 6 speakers connected to it, 2-front, 1-center, 2-surround and 1-powered subwoofer.
Hope this helps.
cancerags
Dec 28, 2007 | JVC RX-664V Receiver
Dell Dimension 4600 PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
