Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to break write protection in pen drive - Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    Scholar:
  • 163 Answers
First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off. • Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software from here and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
how to  break write protection in pen drive - partition_the_pen_drive.jpg Click OK and the drive will be reusable after this.
That should do it
Posted on Aug 01, 2010
  • 182 Answers
There is no write protection in Kingston Pen drive/flash drive
If you are facing any problem in saving the data on the flash drive
Insert the flash drive and go to my computer and right click on the flash drive and select the option to format
Please do check if you have the permission to save or copy the particular data that you are trying to save on Pen drive.
This problem does happen if you are not the owner of the data or you dont have speciic permission to Read/Write
Might be a user profile issue also
Password protect sandisk 2gb
http://download.cnet.com/%7Bvalue=http://www.download.com/usb-safeguard-free/3000-2092_4-75115673.html
USB Safeguard is a portable software program to encrypt and protect data with a password on your removable pen drives using the AES 256 bits encryption.
The main purpose of using a USB pen drive is that you can bring your data with you wherever you go. But if you lose your USB pen drive your data also lose.
This is dangerous if you have confidential files stored in it. Protect the pen drive with a password. USB Safeguard offers users (novice and expert) a friendly yet extremely powerful security solution that fully protects valuable data stored on USB pen drives.
Also, the program has a useful feature that allows you to enter your email or phone if you lose the pen drive. Free version works only with USB Flash drive of size max 2 GB
hope it helps you
Oct 26, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Tip
Removing Write Protection
Trouble:
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Fix:
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button disablewriteprotection_thumb.png
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
on Jun 19, 2010 | Computers & Internet
My pen drive has become write protected and now I want to remove write protection from my pen drive,please help me.
Hi Sir.
Please look carefully at your usb pen-drive to see if there is a small switch on there somewhere that is used to lock and unlock the drive. perhaps you may have accidentally put it in the lock position.
If there is a laser pointer on the drive then using the laser pointer may have caused you to accidentally switch to the write protected mode. most drives have a lock/unlock switch on the pen-drive itself...unless it has a program installed on the drive that has encrypted and locked the drives read/write ability. Please let me know if you have success.
Thank you!
Dec 03, 2010 | Generic Memory USB 2.0 128MB Black Pen...
I have iball pen drive which has been write protect how to remove write protect
Sir I'm sorry for directing you to another site but you will rather undersand it better at this link i'm pasting http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/ your problem will for sure will be resolved
Jun 19, 2010 | Electronics - Others
I have kingston pen drive 32 gb which is write protected .what i
The write protected message appears due to many reasons detailed steps to fix the issue can be found from the following link
May 28, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
WRITE PROTECT ERRORS IN PEN/FLASH DRIVE
Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protection from my pen drive
Dear,
Just do one thing
Copy the data of Pen drive to PC and format the drive. Now paste the data back to the pen drive.
It may work fine onward.
Please try it.
Regards,
Rakesh Kumar
Apr 07, 2009 | Kingston 4GB Secure Digital High Capacity...
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
638 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
