Question about Kensington 72219 Mouse
Does not connect to a mac laptop with bluetooth
I want to connect my samsung montage sph-390 to the internet using the internet connection from my mac powerpc g4 (non-intel) running os x 10.5.8. both the cell phone and the mac are bluetooth enabled and...
i am covering for my sister at work right now and im using my 15 inch powerbook g4...i am rooted and try wifi tether here and there but its too slow so since i knew i was goona be working i tried pdanet last night and it worked and thats what im using right now to get online..i just installed pdanet on my phone then clicked bluetooth DUN and then on my powerbook went to bluetooth and clicked set up bluetooth device and let it run through the setup it found the droidx right away...then i had to pair it with a pin....now each time i wanna connect it i just start pdanet bluetooth DUN and then click the bluetooth in my status bar and mouse over where it says droid x and click connect to network....then the "droidx" turns bold and im connected
Mar 29, 2014 | Computers & Internet
Bluetooth Enable
system preferences - bluetooth
If you don't see the bluetooth icon, your mac does not have a bluetooth card connected (pre-2006 machines or somewhere around there).
Nov 24, 2013 | Apple MacBook Pro Notebook
How do I connect a MacBook 5 and a bluetooth speaker?
Not only do you need a bluetooth connection, you also need an audio program that can access the bluetooth connection.
Like not everything (almost nothing) will work on every USB connection on a PC without the correct driver and program, anything you try to connect with bluetooth, needs the driver and program.
Feb 03, 2013 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
PowerBook G4 Mac Notebook: what is the icon immediately to the left of the an...
It's most likely the bluetooth icon. You can use bluetooth to up/download files from a bluetooth compatible phone, or other device into your laptop.
You need to "find" and "connect" both pieces of equipment to work together first.
Similar to a bluetooth headset with your phone.
Easy to do and then it's easy to transfer files..
May 17, 2010 | Apple PowerBook G4 Mac Notebook
Can i download from the internet onto my laptop and then to my phone without using a usb cable?
Yes! you can download your files to your laptop as normal, then connect your laptop and phone via a bluetooth connection... The bluetooth menu is next to the airport menu on the desktop.
Simply set your laptop and phone to communicate (similar to setting up a bluetooth headset). Then look on the desktop for a drive or folder icon with your phone name. then install the files in the correct folder.
May 13, 2010 | Computers & Internet
How do I sinc my samsung hd 8910 to my apple mac
If you are trying to connect using bluetooth you can browse the phone. Go to system preferences and then click on bluetooth at the bottom right of this window
underneath the plus sign is "show Bluetooth status in the menu bar", click on this and it will make it easier to connect to your phone the next time you want to connect. Now click on the plus sign (+) this will bring up the Bluetooth Setup Assistant. click on continue select mobile phone. The blue tooth will start scanning (please ensure that your blue tooth is switched on your phone and ensure that it is discoverable). Hope this helps.
Nov 11, 2009 | Apple MacBook Pro Laptop Computer with...
How do I connect my Samsung Jet to my Apple Mac running Osx 10.5.8 for using it as a modem for internet connection.
If your Mac has Bluetooth, you can connect to the phone via a bluetooth connection and use it as a modem. You first need a connection profile on the phone that will allow an IP connection (data) to your phone network, either via 3G or GPRS, though the former is potentially faster.
Then you need to Go into system preferences->Network on your Mac and create a Bluetooth connection profile that may need a user name and password to connect to your phone networks data access point.
Then select the IP profile on the phone, turn Bluetooth on. Turn on Bluetooth on the Mac and select the Bluetooth connection profile in Network on the Mac and click on the connect button, it should then connect and away you go
Oct 23, 2009 | Samsung Jet S8000 Cell Phone
Apple Mac connectivity
HI buddy ,you can download the drivers from
brothersoft.com
bitcomet.com
cnet.com
Have a great day:):)
Plz rate me for my solution so that I can improve myself and be more helpful:):)
Prasanth83:):)
May 25, 2009 | Samsung J700 Cellular Phone
Apple wireless mouse no longer connects
please remove the battery and check the mouse with saperate good battery also.update the mac os x with the latest avilable update.and update the bluetooth drive for mac.the issue will get solve
Oct 27, 2008 | Apple (ABT-M9269ZA)
Kensington 72219 Mouse Logo
22 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Pierre Legault
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
