Question about Candy AQ130 Front Load Washer
Will not drain
I have a Candy Aquaviva 1300 front-loading washer/dryer. The cycle does not seem to continue through to 'spin'. Even though i can hear the machine humming nothing happens. As a result (I assumed) the water isn't draining and I'm left with a 4cm deep puddle in the bottom of the barrel.
I have a similar problem with my Candy WM801. However I cannot find the filter, it does not appear to be at the front... pulled it out and can't see anything obvious at the back either. Looking online for manuals, it should be simple shouldn't it!
Posted on Sep 23, 2008
Try cleaning the filter as when this gets all clogged up the water doesnt drain thru the pump
Posted on May 25, 2008
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
I CANNOT FIND THE LINT TRAY/HOLDER ON MY CANDY AQUAVIVA 1300 WASHER DRYER. I FIND THE DRYER GIVES THE CLOTHES A DAMP SMELL WHEN DRIED. IS THIS DUE TO LINT BUILD UP?
This is usually located either near the bottom front, possibly behind a plate, or inside the rim of the drum. Check the user manual.
May 26, 2011 | Dryers
Candy aquaviva 1300 no heat while drying
disconnect the unit from the mains supply and remove the lid you will find a thermostat with a red button on it, press this and if you hear a click, problem solved to prevent fault reoccurring always let the dryer cycle finish its self as stopping it early can cause the heater box to overheat.
regards
Ian.
Apr 17, 2011 | Candy Dryers
Machine seems to work, but will not empty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Candy DQW150 Front Load Washer / Dryer
My candy 514 is not draining properly - even after a spin cycle the clothes are still very wet suggesting that water is not getting out
I have a GE and my friend has the same problem with his whirlpool. Removed the frt cover adn looking at the washer on the left side there is a clean out drain. My kids leave things in pockets and filles this drain up and washer will not drain. it is very easy to do
Oct 26, 2009 | Candy CNW136 Front Load Washer/Dryer
Candy Aquaviva 1300 washing machine
fabrick condictioner drawer stays full can you help me bernie
May 21, 2008 | Candy AQW130 Front Load Washer / Dryer
How to use the dryer of my Candy Aquaviva 1300 please?
wahing machine works great but a cant work out how to use dryer
Feb 21, 2008 | Candy AQ130 Front Load Washer
Candy aquaviva 1000 es
Are you sure that this not is the cooldown phase of the mainwash? Most frontloaders have this feature.
Nov 28, 2007 | Candy AQUA1000T Front Load
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Candy AQ130 Front Load Washer Logo
685 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
