Question about Whirlpool AWM8143 Front Load Washer
Whirlpool front load washer does not start. The
Whirlpool front load washer does not start. The lights are on and the motor makes noise but no water is getting into the machine. The "door open" light also stays on. It has been getting very noisy especially during the spin cycle and has also started jerking back and forth resulting in an F6 error message.
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$#%
Posted on Sep 21, 2010
How do I fix
Try removing the wall plug for 30 seconds and then plug it back in. This will often reset the logic board. If it doesn't, you need a service engineer, as yours is a strange fault.
Apr 09, 2016 | Whirlpool Duet WFW9550 Front Load Washer...
Whirlpool front load washer won't cancel cycle/unlock door
You may have a problem with either your drive motor, motor control unit or main computer board (known as a CCU).
PS Check for the obvious first. Make sure the drive belt is still attached and not broken before getting too deep into troubleshooting everything else. NOTE: More commonly, this is an indication of a motor control unit failure.
Aug 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
MY whirlpool WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
Maytag LAT3600A Top Load Washer
1 Points
Nov 27, 2012 | Maytag LAT3600A Top Load Washer
Whirlpool wshser-dryer: water won't drain, cycles won't start
You need to give more info in order for a diagnosis. Is this a compact stack unit or an all -in -one unit or an interconnected washer/dryer pair ? Is it front load or top load washer ? What do you mean by "dry cycle"? Is that dryer cycle or is it washer cycle without water ?
Usually when water cannot be drained it is a bad coupling connector on the motor drive, or a bad or clogged pump (small socks have been known to get sucked in an lodged in the pumps); in either case you need a good mechanic or a service person to handle the repair because it requires opening up the shell of the unit and getting to the motor/pump assembly.As always, disconnect the power cord before diving into the unit. Good Luck, Macgivor.
Sep 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool AWM8163 Front Load Washer
My whirlpool duet washer is making a funny noise
try removing the top cover to the unit, 3 screws across the back. after ermoving check to see exactly wehre noise is coming from. some times a solid "smack " witha screwdriver will quiet teh dispensor motor if needed
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool noise
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Check that the drive belt is OK take it from there thenClose Ireland bye bye
Nov 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not drain or spin motor making clicking noise
Likely has debris in the filter.
Open the bottom access panel (3 screw on bottom front lip)
open the filter access and be ready for some water spill ,have towels.
clean and check the pump impellers for freedom of movement.
if you still have noise after this you may have to go deeper past the pump and remove the hoses as the debris can be past the pump now.
Or take the machine outside and run water up the pump using a water hose to clear it. be inventive
Oct 26, 2007 | Whirlpool GHW9100L Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
146 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
