Question about RCA RCR450 Remote Control
GE Universal RC24929-B Need set-up code I want to be able to change channels from remote. Thank you
    President:
  • 1,932 Answers
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Posted on Aug 01, 2010
G e universal remote codes
GE 0051 0343 1454 0047 0178 0135 0747 0021 0451 0174 0180 0027 0092 0282 0030 0560 0287 0109 1922 0335 0625
Jul 12, 2017 | Televison & Video
I need the code for ge universal remote rc24993-c to connect to a sony television please
Universal remote allow you to control multiple electronic devices with a single remote. You can use the remote to work your TV,DVD player, cable boxes and other devices from the comfort of couch.Philips is a popular manufacturer of universal remotes.to program a GE remote for SONY TV,you will either need to input the device code or perform a code search
direct entry
first.turn on your TV manually. next.press down and hold set-up on the remote.the red indicator light will stay lit.after that.press the TV device button to let the remote know you wish to program a television then.enter your device four digit codes on the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the number zero in the beginning of the codes finally.test the remote to ensure it works.with the turned on,press the channel button and see if the TV responds..if it is work the remote programmed and you are done,if it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
Mar 09, 2011 | Televison & Video
Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
Apr 21, 2009 | GE JASRM24912 Remote Control
Need ge universal tv codes
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 05, 2009 | GE RM24912 Universal Remote Control
My appliances need codes
Each of the makers of the products you mention have this on their website,
if you don't have the manual for the universal remote then
http://www.jascoproducts.com/support/universal-Remote-codes.asp
it has the codes
Feb 03, 2008 | Televison & Video
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Codes for ge universal
Universal remote codes change every year depending on what the most popular models are on the market. If you have tried "code search" and have been unable to lock-in a code for your device, this means a code for your model is not available in this remote. The memory chip in a universal remote can hold only a limited amount of information. There are no lists of models for each of the brands.
Oct 25, 2007 | GE JASRM24912 Remote Control
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
How do i!
make sure the batteries are good and installed correctly. turn on device(manually) press and hold (setup) button until the red indicator stays on. then release the set up button. press and release device button(tv,vcr ect) the red indicator light will blink, then stay lit. press channel up until the device changes channel.The red indicator light blinks and stays lit.if you over shoot the code required press channel down to back track. now press and release the mute button to lock in the code.
Jan 13, 2007 | GE RM24912 Universal Remote Control
RCA RCR450 Remote Control Logo
2,985 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
