I have to re-fresh almost every minute it is driving me nuts
    Sergeant:
    Champion:
  • 301 Answers
Ok , check the ip getaway, when you have that problem in that moment go to start , then find execute. write cmd and then wirte for exemple if you getaway is 192.168.1.1 try with this in cmd ping 192.168.1.1 if you dont recive the anwser your modem is bad , call to ISP support
Posted on Aug 01, 2010
My peouget 207 was done a cylinder head, now it starting for few minutes and cut off,it does not want to idle,it had been standing for over a month
Add fuel conditioner to a few gallons of fresh fuel, swirl and add to tank. Allow about 15 minutes to mix. Star engine and hold RPM to just over idle speed. Run for 10 min. Then drive at highway speed for about ten minutes. If there is room in the tank , add more fresh fuel and additional fuel conditioner. If this has not solved your issue, pull and regap or replace plugs. If there is any light coloured goop on any of the plugs, you may have a leaking cylinder head gasket. Replace the gasket and re-clean the plugs.
Apr 04, 2016 | Cars & Trucks
My autopilot wont disengage.i flip the lever on the back but unit stayes navigating
when you have a raymarine wheeldrive mk2 you have to loosen the belt. For that purpose, there is a nut on the back;
Also it can help to flush the drive with fresh water.
Apr 05, 2015 | Boating
Wipers worked for 1 swipe and stopped straight up. Motor sound is audible. Wipers stopped swiping.
At the base of the wiper there is a nut, it might be under a snap on cover. Move the wiper arm down into parked position, tighten the nut and the wipers should work. That is most likely the case but... If not it could be the ball and socket on the mechanism under the fresh air vent. Last option is the wiper motor gear drive.
Dec 30, 2013 | 1998 Ford Windstar
Adjust belt drive rear wheel
If the question is how to adjust the drive belt, it's actually pretty easy. With the bike in the side stand you should have about 1/4-3-/8 deflection in the middle of the drive belt pushing with 10lbs of pressure. The best thing to do is purchase a drive belt deflection tool that you can set to 10lbs. If you need to adjust the belt, you loosen the axle nut on the right side and turn the axle from the left side to loosen or tighten the belt tension (Harley uses eccentric shaped washers on both sides of the axle to make this adjustment easy). Once you made the adjustment and tightened the axle nut, double check the deflection to make sure it didn't change while tightening the axle nut. Takes about 10 minutes to check and adjust.
Nov 04, 2013 | 2006 Harley Davidson FXDBI Street Bob
Mine is a Poulan 55 with Side Discharge Mulch Front Wheel Drive SelfPropelled Lawn Mower With High Rear Wheels it has a 5.5 Briggs and Stratton the problem is when I try to start it I push the prime button...
The carburetor could have some water inside of it. At the bottom of the carburetor there is a nut, you can remove this nut with a 1/2 inch wrench or a socket. It is usually easier with a 12 pt socket. I would clamp the fuel hose to keep extra fuel from going through the carburetor when you take out the nut. Now take the nut loose and the fuel bowl that the nut was holding onto the carburetor should be loose enough to come off. Keep the bowl steady as you lower it down and you should be able to see fuel on top and if there is water in the carburetor bowl it will be on the bottom of the bowl. It is usually darker than the fuel and is easy to detect. If you find water in the carburetor bowl then I would do a visual check on the bottom of the carburetor to see if there is any corrosion from the water being inside of the carburetor. The usual color of the bottom of the carburetor is a dull grey color. If it is white, or if there is a "milky" color to the fuel in the bowl the carburetor could be ruined. If there is no corrosion, but there is water in the fuel bowl I would remove the rest of the fuel from the fuel tank and clean the fuel bowl before putting it back on. Add some fresh fuel (from a gas station) not from the gas can, unless you have recently gotten fresh fuel (30 days or less). The unit should now run correctly after being primed.
Mar 29, 2011 | Poulan Pro 22inch 625 Series Briggs ...
2001 kia sportage need to get info on how to change the timing belt, 2.0 motor forward facing motor, needs power steering replaced, timing belt.
Below are the steps..
Disconnect the negative battery cable. Remove the two fresh air duct mounting bolts on the radiator. Loosen the fresh air duct clamp at the intake housing. Remove the hose at the resonance chamber. Remove the frech air duct. 2bea4d1.jpg Remove the five cooling fan shroud bolts. ab00c68.jpg Remove the four thermo-modulated fan nuts. Remove the four thermo-modulated fan cooling fan shroud at the same time. 289c5ca.jpg Loosen the two generator mounting bolts(A and B). 2a96c03.jpg Loosen the generator drive belt from the generator by loosening the adjusting bolt(C). Remove the generator drive belt. Remove the fan pulley. Remove the four splash guard mounting bolts and splash guard. f912ce0.jpg Loosen the A/C idler puller nut(A). c0690b5.jpg Remove the A/C drive belt by loosening the adjusting bolt. Loosen the power steering pump lock bolt and mounting bolt. 843d3b3.jpg Remove the power steering belt. Remove five bolts and the upper timing belt cover. Refer to Timing Belt. Remove two bolts and the lower timing cover. Refer to Timing Belt. Loosen the tensioner lock bolt and pivot the tensionder pulley outward to remove the tension from the timing belt, then re-tighten the tensioner lock bolt. 7ca4ca0.jpg NOTE: Tightening Torque : 27-38ft·lbs(37-52N·m) Mark the timing belt rotation for proper reinstallation if it reused. Remove the timing belt. Be careful not to allow oil grease on the belt. c5d4c02.jpg Regards, Jeep Brainy
Sep 16, 2009 | 2001 Kia Sportage
1994 FXDL misfires for ten minutes of driving
Start with a fresh set of spark pulgs, adjust your choke or open it a bit as it warms up.
Aug 22, 2009 | Harley Davidson FXDL Dyna Low Rider...
Got virus laptop will not restore to earlier date takes about 12 to 15 minutes to sign on to computer. Would like to restore to origial state but that does not work either help me
You need to install a fresh copy of your operating system You need to be able to completely erase your hard drive and start fresh. If I were you I would consider changing the hard drive completely and starting fresh with a new copy of the operating system. It sounds like a worm and it has eaten through all of your restore data.
Jun 21, 2009 | Computers & Internet
Where can I buy a replacement Miller's Choice Bread Maker Pan please?
The Swan fastbake bread maker is the bestBread maker that I have ever owned. Now I will let you into a sad secret I own five breadmakers at present, Panasonic,Hinari,Morphy Richards,and a Crown. The Swan comes up trumps every time.The auto nut dispenser is a nice touch.The pan makes a good size family loaf ideal for the beginner and for the more adventurous amongst us a fully individual program setting for doe mix adjust heat and mixing times. The bread comes out just as you would expect to see a loaf at the bakers but without all the rising agents and various additives that are supposed to keep yourbread fresh for `seven` days. Seven days, I have trouble keeping the bread seven minutes once the family tribe get the scent of fresh baked bread.
Jun 19, 2009 | Kitchen Appliances - Others
Dryer runs for 15 minutes and stops
check the in-line limiters on the heating coil tube.
Jan 15, 2009 | Kenmore 62882 Electric Dryer
Computers & Internet Logo
Alun Cox
David Payne
David Payne
