Question about Cub Cadet Garden
Remove headlamp cover cub cadet lawn tractor
How do I remove the clear plastic headlamp cover from my cub cadet lawn tractor LTX4500 without breaking the plastic cover?
mickey813
  • 472 Answers
SOURCE: Lawn Tractor will not start.
re place the fuse its a small 10 to 20 amp is by the solenid wer the batt cabel hooks up frome the batt
Posted on Oct 04, 2009
  • 13 Answers
SOURCE: cub cadet lawn tractor, ran out of gas. After
I would bet that the throttle shaft is worn and has a lot of play in it on the carburator. This is very common. The best bet is to have the carburator worked on by a small engine repair shop, or get a replacement one.
Posted on Jun 10, 2010
daneinwv
  • 124 Answers
SOURCE: NEED A WIRING DIAGRAM FOR
My name is Dane and I am going to try to help you solve your problem.
Here's a link to where you can find your 3000 series service manual. You will find the schematics starting in chapter 17. Please find your correct engine configuration to match the correct schematic.
http://www.mymowerparts.com/pdf/Cub_Cadet/Cub_Cadet_Service_and_Repair_Manuals/
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Posted on Dec 04, 2010
woobie dog
  • 1273 Answers
SOURCE: I own a Cub Cadet Hydrostatic Lawn Tractor, not
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Posted on Mar 07, 2011
  • 180 Answers
SOURCE: My 1650 cub cadet lawn
Check and replace the coils.
Posted on Aug 26, 2011
Starter motor hds 2165 cub cadet
One post, take a cheap thin wrench. Heat it, bent 90 d to fit in the space.
Apr 03, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
How to r/r a pto on cub cadet lawn tractor
Hi kenneldog60,
Can you please elaborate your question with the below details ?
  1. Confirmed model and make of your machine or lawn tractor.
  2. The problem that you are facing in clear language without any abbreviations.
  3. What else have you tried to solve the problem.
Waiting for your reply.
Jun 28, 2011 | Peg Perego Cub Cadet Tractor
982 cub cadet 3 blade w/ idler pulley deck belt diagram
hi there pauly 46 here
here is web site for streetsign cub cadet 982 46 " deck with 3 blades
http://www.partstree.com/parts/?lc=cub_cadet&mn=336+46%22+Mower+Super+Garden+Tractor&dn=0057000002
this shows deck belt routing
and here is website area for 982 parts break down for model 982 cub cadet
http://www.partstree.com/parts/?lc=cub_cadet&mn=982
take a look cheers hope it helps
pauly46
Apr 28, 2011 | Cub Cadet Street Sign- tractor lawn riding...
How to remove deck on 1045 cub cadet to remove and sharpen blades
You should be able to remove the blades without removing the deck
They bolt on from underneath with either a single or double bolt set up
90% + are single bolt
Mar 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How do you remove the front tire on Cub Cadet LT1045? Seems to have a plastic hub over bolts.
Thats a plastic dust cap.Remove it very carefully so not to damage it. Then under the plastic cap will either be a Cotter pin or and E clip remove what is there and slid the tire and wheel off the spindle. These are a bear to break down and dismount and or remount. Unless you have a mini tire changer. I use my huge vise and a shaft the size of the spindle.I use motorcycle or bicycle tire irons. ITs a hassle believe me.
Oct 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
How do I change the drive belt on a 1500 Series Cub Cadet Lawn Tractor
Go to www.partstree.com click on Cub Cadet, enter the model number that's under the seat and that will give you a diagram.
Jun 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Flat Tire
It can be pried off with a screw driver. Under it is a cotter pin and washer
May 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Forward rev shaft seal leaking on 1650 cub cadet
I would say no. your best off to take that in to shop services riding tractors.
Mar 08, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
412 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
