Question about Vacuums
How two tighen belt on wide path foldaway vac
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=543467
Generic problem for all Vacuums
How two tighten belt on
Posted by davidrosy on Apr 24, 2008
How two tighten belt on wide path foldaway vac
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There really is no way to tighten the belt, the belt does need to be changed every 4 to 6 months as recommended by the factory manufacturer and to store any extra belts in a Ziploc bag in the refrigerator to keep them fresh. Your belt has stretched and therefore is not cleaning as well as it should, so If you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. I believe the Widepath is made by the Hoover Co and the phone # and website are listed below if I am correct.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 25, 2008
Where to purchase belts
Independent sewing and vacuum, or sew & vac stores, typically carry a wide selection of belts. Be sure to know your model number of your vacuum, even if you have the old belt, as they stretch considerably and can be difficult to match an old belt with a new one.
Jul 18, 2014 | Hoover U6630-900 WindTunnel Bagless...
Spray path is too wide. Is there a deflector available
I had the same problem with my proheat. The water would spray a wide path out the sides. I think it must be a defect as I have replaced my unit due to another problem. I purchased the Bissell machine without the heater and the nozzle is fine.
May 14, 2010 | Bissell 1425 Little Green ProHeat Handheld...
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Brush on hoover wide path does not spin around.
remove the bottom cover and check the drive belt.if belt is ok then your brush motor could be bad.
Jan 29, 2010 | Hoover U5172900 Fold Away Widepath Bagless...
I just bought a foldaway hoover with wide path. I plugged it in and started to vacuum and dust flew everywhere. Walmart would not give me my money back so they gave me another hoover foldaway with the wide...
Take to Walmart, plug it in and start to vacuum THEIR floors!
Try removing the dust container and look for anything blocking airflow including the HEPA filter. Make sure the dust cup has a seal where it joins the vacuum. The fix is probably simple, but it shouldn't be up to you to do so!
Nov 16, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Our vacum isn't picking up @ all.we did have some thread around the brushes, about an inch wide. it has an odor like it is getting hot. the vacumn is about 1-1/2 yrs old. we need help. thanks BETTY COX.
Hi, The most likely cause would be a blockage. If you remove vac hose, does it **** on your hand? secondly, with the vac unplugged, Can you turn the brush reasonably freely ? Is the drive belt on?
Aug 31, 2009 | Vacuums
Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
Aug 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Hoover Steam Vac Wide Path
Don't have one yet, but your problem might have solved mine. Bought this cleaner used and now will go to vacuum store to buy spring. Water just pouring out like a faucet.
Mar 27, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
80 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
