Question about HP LaserJet 3015 All-In-One Printer
Hp3015 can scan and copy, cannot print original disc cannot recognise the printer is connected when I try to install the driver
    Sergeant:
    Champion:
  • 301 Answers
Go to control panel , sistem and go to administrator divices and update the printer diriver from there
Posted on Aug 01, 2010
I need a driver to install my home mac 10.4.11
go to the manufacturers website and download the current software for your printer.
Dec 13, 2014 | Office Equipment & Supplies
Will not print but it will scan and copy
Some times printer manufacturer provide print and scanner drivers separately, did you try to find "print driver"?
Or... some times when you plug your device prior to start installation agent, it do not work until... you re-connect your printer in to other USB port. Try it!
Aug 22, 2012 | Lexmark X4530 InkJet Printer
Can't get the scanner to work
Check if it's a hardware, software or a USB connection problem.
If you are able to make a copy using the Copy button on the printer operator panel, then hardware is good.
Try to disconnect and reconnect the printer into your computer.
Then send a print job. If print job is sent successfully, then USB connection is good.
Try to update your printer driver by reinstalling the printer software. If you are scanning a document for editing, make sure the Lexmark OCR scan software is installed on your computer. The scan software is avialable only on the installation disc that came with your printer.
If problem continues, please contact Lexmark Technical Support Center to further troubleshoot this problem.
Jul 06, 2011 | Lexmark X8350 InkJet Printer
I am trying to install a new computer which previously had a different HP3015 printer. How do I get the computer to recognize the new HP3015?
Before you start the installation it would be best to uninstall the old printer driver. Then connect the new printer, put in its disk, wait until that starts to load, and when it prompts you, turn on the new printer. If this helps, Please Rate me! :)
Jul 14, 2010 | HP LaserJet 3015 All-In-One Printer
Epson stylus sx205 won't print on my macbook pro
Def sounds like a driver error, do you get a yellow mark next to your printer driver or is it ok?
You could try & see if there is a more recent driver from epsons website
Nov 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Can't get it to scan. It prints, it copies, but no scanning. It's a photo I'm trying to scan. I switched to Mac from PC recently. If that's the problem, what do I do? Tks.
Did you install the Canon software?
Most canon's will print without any software being installed on a mac. Scanning needs the software.
Anyway. Do this.
Open your applications folder and look for an app called "Image capture" When it opens up it should - all being well - recognise the scanner and do an automatic preview. Once it's done that select what you want to scan by drawing a box around it, this should activate the scan button. Press that and it will probably ask what you want to do with the scan and what sort of file you want.
I'll leave that up to you to decide.
You may find that the next time you try to scan (on another occassion that is - not doing another scan straight away after the first) that the scanner is not recognised. It happens periodically with some Canon MPs and I don't know why. If it does happen, the easiest solution is to restart the mac. Sometimes unplugging the USB and replugging sorts it.
Aug 22, 2009 | Canon PIXMA® MP530 All-In-One Printer
I can't print scanned material to full size.
You can try the freeware at the link below:
http://www.bestsoftware4download.com/software/t-free-freekapture-download-npbskbaz.html
The description states: "You can also use FreeKapture as an 'ad hoc' copy machine (by using your printer drivers 'how many copies to print' option)."
It works with all twain compliant scanners. Download and install and then point it to your scanner.
Good luck, and please let me know how it works out for you.
Mar 19, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
Lexmark X1270
If you have the original installation disc, reinstall the software.
Windows probably trashed the Lexmark software.
If you hear the machine working when you try to copy or scan and the light source doesn't come on, you will need the lamp replaced; on some units and easy job, on others, you may end up saying 'to hell with it.'
Jun 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Got new computer and now my printer will not scan.
If you cn copy then the Scanner and Printer both are fine. The only thing you are missing is the Scanner driver/utility. Install the same from the Driver Disc you got with the Printer and your problem is solved. If you don't have the same download from the manufacturers site.
Feb 04, 2008 | Lexmark X5150 All-In-One InkJet Printer
Streaking
Check the scanning glass bar. If you scanned something that had whiteout on it, a lot of times some of the whiteout will get on the glass and will cause streaks in the prints. Clean it with alcohol.
Oct 16, 2006 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3015 All-In-One Printer Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
