Question about Whirlwind FH-778 Air Conditioner
My air conditioner keeps freezing up - Whirlwind FH-778 Air Conditioner
  • 384 Answers
Dear sir /madam
please make sure first your air conditioner unit is clean and it,s out side i mean hot ( condenser )side fan motor is working and it,s getting same result then it can be low gas problem ,it,s need to refill the gas so please contact to trained technician for refill the gas.
hope answer the question
thank you
please vote!
Posted on Sep 16, 2010
What is wrong with and Air Conditioner that continues to freeze up?
the ac cant keep up,you need a bigger ac or a smaller room,if the ac needs to keep cooling,it doesnt have a chance to cycle
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
My air conditioner is freezing up
Hello, the unit will frost from either low airflow ( dirty coil or filter) or a low refrigerant charge due to a leak.
Jul 04, 2012 | Sharp Comfort Touch AF-R120EX Air...
It keeps freezing up if you put it past #5
Hi and welcome to FixYa. I am Kelly. Freeze ups are caused by a couple things.
1. The first thing is a dirty evaporator coil. Air conditioners that run 24 hours a day should be thoroughly cleaned every 90 days.
2. The Blower fan wheel is dirty
3. The fan motor is not running fast enough.
Most of the time these 3 items listed above are the main reasons and Air Conditioner Freezes up.
Thanks for using FixYa,
Kelly
May 10, 2010 | Friedrich Casement SC06H10D Air...
Evaporater freezes up after running for aa short while
HELLO THERE:
When you set the temperature settings down around 64 or lower the unit will freeze up so i recommend to keep it at around 68 or 70 ok this will keep it from freezing also make sure that the unit is free of any obstructions so the air can freely get to the unit ok?
best regards michael
Aug 27, 2009 | Whirlpool ACM184XP Air Conditioner
My air conditioner lines keep freezing up.
You have a blockabe in the distributor tubing which will need a professional to sort out.
Jun 25, 2009 | Heating & Cooling
Air keeps freezing up
you may have a ref. leak or possible the fan motor is not running as fast as it is supposed to.
Paolo
May 05, 2009 | Heating & Cooling
Freezing Up
sounds like air is not flowing properly thru the a/c. if there is a filter you can pull out remove it and clean it.
Robert
Sep 01, 2008 | Fedders A6X05F2D Air Conditioner
Fridgedaire; freezing up
If the coils freezes up half-way-down and lower is due to low freon psi.
Aug 21, 2008 | Frigidaire FAC126P1 wall/window Air...
Goldstar R1804H
well u should take it out the window and dran the water out unite thwe water is gone then put it back ang if u still see that its freezing try it again and then put it one and u my have to do this offin to keep it from freezing
Jun 28, 2008 | Goldstar R5050 Air Conditioner
Amana window air conditioner 10000 btu
Mine has done this alot, mostly because I live in a state with ALOT of wind, and in an area with ALOT of dirt. Sounds like your coils are dirty. Try cleaning it out, or having it cleaned out. If you spray it with water just make sure your compressor is facing up and you don't use too much pressure. Hope this helps
Jun 12, 2008 | Amana PTC074B25AE Electric Heat Air...
Heating & Cooling Logo
134 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
